Analyzers
5285 Discussions
How to report comparison results from command-line?
Lau_L_
I have used the Compare feature from GUI by selecting two amplxe files from different runs. How can I do this on the command-line, reporting out e.g. the Summary pane of a comparison?
Thanks!
David_A_Intel1
Hi Lau:
I'm sorry, but right now it looks liks you would have to do this manually.  For example, output the summary report for each result in CSV format and then use a script to process the output of each report to do the comparison.
[bash]$ amplxe-cl -report summary -format=csv -csv-delimiter=comma -r r001hs > r1results.csv
$ amplxe-cl -report summary -format=csv -csv-delimiter=comma -r r002hs > r2results.csv
$ awk -f compare.awk F1=r1results.csv F2=r2results.csv > comparison.txt
[/bash]
Something like that.  Or, whatever your favorite scripting language is. ;)
Alternately, you can import the results in the GUI and use the Compare functionality there.
Peter_W_Intel
Probably you can compare them in command line directly. For example:
# amplxe-cl -report summary -csv-delimiter="," -r r007runsa -r r008runsa > r7-r8-diff.csv
David_A_Intel1
Even better!  Cool.  Thanks, Peter! ;)
