Analyzers
5285 Discussions
How to visualize the source location for the performance issue reported in Trace Analyzer for Python
Fleza
Hi, I am using Trace Analyzer with Python code ,but I am not able to view the source location for the performance issue reported in the performance assistant panel:
I added this to my mpiexec command to activate the tracer and exported the PCTRACE but variable, but I cannot see the line number and more details for the source location:
export LD_PRELOAD=libVT.so:libmpi.so:libVTfs.so:libVTim.so
export VT_PCTRACE=5
export VT_CHECK_TRACING=on
mpiexec -genv VT_LOGFILE_FORMAT=SINGLESTF -genv VT_LOGFILE_NAME=tracer_result_scatter-array.stf -n 4 -ppn 4 python scatter-array.py
 What other configurations do I need to add to access python code details?
yuzhang3_intel
Let me check and give you an update.
Jennifer_D_Intel
Intel Trace Analyzer and Collector (ITAC) only supports C/C++ and Fortran. Since the decision was made to discontinue ITAC, full support for Python was never added. You can use VTune to view Python code though.
More documentation is here:
https://www.intel.com/content/www/us/en/docs/vtune-profiler/user-guide/2024-2/mpi-code-analysis.html
https://www.intel.com/content/www/us/en/docs/vtune-profiler/user-guide/2024-2/python-code-analysis.html
Fleza
