Analyzers
5298 Discussions
Inspector can't inspect child applications
Hodara__Joachim1
Last year, I created this thread to report a bug in Intel Inspector: It is not currently possible to inspect a child application launched from a script.
In the simple example attached here, I have a script run_main.bat which launches a main.exe executable. If I select run_main.bat script as the Application, and main.exe as the child application, I get the following error (but I can confirm that the executable runs properly):
The issue was confirmed by Intel in the previous thread, and I was told that a fix was coming in a future release.  This was on 6/10/2022. Today, I tried again with Intel Inspector 2023.2, and I get the same error.
Is a fix on its way? Is there a workaround I could use to bypass the issue?
Thank you,
Joachim
Ruslan_M_Intel
Here is workaround - you need to install 'bash' on your windows machine (e.g. git-bash). Then you profile 'bash.exe' (pass your bat file as an argument - no need to rewrite any script) but child app will be 'mem.exe'
AlekhyaV_Intel
Thank you for posting in Intel Communities. We have referred your old thread and contacted the admin team regarding this issue. We will get back to you soon with an update.
Alekhya
AlekhyaV_Intel
We apologize for the delay caused. The version against which you reported is no longer targeted for fixes. As a workaround you could start inspxe-cl from inside the script used to start your application.
If this resolves your issue, make sure to accept this as solution. This helps others with similar errors. Thank you!
Alekhya
AlekhyaV_Intel
Has the workaround provided helped? Could you please give us an update whether we could close this case?
Alekhya
Hodara__Joachim1
What do you mean by "the version against which you reported is no longer targeted for fixes"? This is failing on the latest version of Inspector (Intel Inspector 2023.2).
Unfortunately, the workaround won't help, because I don't have control over the launcher script. It's a complex piece of code owned by our infrastructure team, which fires my executable at some point.
Best,
Joachim
AlekhyaV_Intel
We apologize for the confusion caused. We got an update from the admin team that, as of now, there are no plans to address this issue about child application in Intel Inspector.
We apologize for the inconvenience caused.
Alekhya
Hodara__Joachim1
Isn't that one of the core features of Intel Inspector? They are going to leave it broken like this?
Thank you,
Joachim
Ruslan_M_Intel
Hodara__Joachim1
Thanks for the tip. However, I already tried this, and although it gets me a bit further (I no longer get the Inspector error), Inspector does not catch the basic memory error in my test (it does when I run the executable directly).
Ruslan_M_Intel
I was able to get result for 'mem.exe' which is called by 'mem.bat'. Do you mean that you have much longer script chain? (e.g. main.bat->wrapper1.bat->myscript.bat) If you describe your setup more detailed I will try it too.
AlekhyaV_Intel
Hi @Hodara__Joachim1,
Could you please give us an update on this issue?
Alekhya
Hodara__Joachim1
Hi @AlekhyaV_Intel and @Ruslan_M_Intel ,
Apologies, I didn't see @Ruslan_M_Intel 's answer from last week. I had already tried a similar workaround, but using the windows command, and that did not work (Inspector didn't fail anymore, but it didn't catch the memory error either).
However, I just tried using git bash, as suggested above, and that worked. Not sure why, but that's good enough for me. Thanks!
AlekhyaV_Intel
Glad to know that our workaround worked for you. Thanks for letting us know. If you have any further queries, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
