Analyzers
5273 Discussions
Intel Advisor caused an assertion failure on windows 10 + Visual Studio 2017
CRquantum
I repeated have a problem on my windows 10 + visual studio 2017.
The Intel OneAPI version I use is 2021.3.
Every time I try to use Intel Advisor in the analysis windows, if I choose Accuracy to be more than Low, like if I choose Medium or High, I will encounter the error,
See screenshot attached,
It cannot send crash info automatically, but here I attach the crash_info.txt
When this issue occur, the Visual Studio basically freeze and I have to terminate it.
Does anyone know what is wrong and how to solve this crash problem?
Thank you very much in advance!
Mariya_P_Intel
Hi @CRquantum, the issue was escalated to Advisor developers. I will notify you when get more info from them.
CRquantum
Thank you very much indeed!
In case you need my project file. Here it is attached.
There is another issue seems has been reproduced by some other users too, perhaps you could also have a look when you have time.
https://community.intel.com/t5/Intel-Fortran-Compiler/O2-O3-gives-obvious-wrong-results-simple-30-lines-MWE-attached/m-p/1316212#M157629
Thank you again!
Zakhar_M_Intel1
Just to let you know that the identical crash has been fixed in advisor some time ago and the fix is available in the latest updates. So upgrading to latest Advisor Update (I would use 2021.4 version which is already released or to be released some time this/next week) should help.
Thanks!
Mariya_P_Intel
Hi @CRquantum, Advisor 2021.4 is available for download as a standalone tool at https://software.intel.com/content/www/us/en/develop/articles/oneapi-standalone-components.html#advisor or as part of oneAPI Base Toolkit 2021.4 at https://software.intel.com/content/www/us/en/develop/tools/oneapi/base-toolkit/download.html
Please let us know if using the new version of Advisor helped.
AthiraM_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
