Analyzers
5284 Discussions
Intel E810 Bit error rate test instruction
liwenjiong
When the optical module is connected to the E810 network adapter and the port is linkup, what command can I use to test the bit error rate of the port?
yuzhang3_intel
You can get help from the ethernet forum below:
https://community.intel.com/t5/Ethernet-Products/bd-p/ethernet-products
liwenjiong
Thank you for your reply, but I can't find any helpful results on this page. Or does Intel have a similar tool that can read the bit error rate of a port?
The following is some information about the network adapter.
[root@localhost ~]# ethtool ens1f0
Settings for ens1f0:
Supported ports: [ FIBRE ]
Supported link modes: 25000baseCR/Full
25000baseSR/Full
50000baseCR2/Full
100000baseSR4/Full
100000baseCR4/Full
100000baseLR4_ER4/Full
50000baseSR2/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: No
Supported FEC modes: None
Advertised link modes: 25000baseSR/Full
50000baseCR2/Full
100000baseSR4/Full
Advertised pause frame use: No
Advertised auto-negotiation: No
Advertised FEC modes: None
Speed: 100000Mb/s
Duplex: Full
Auto-negotiation: off
Port: FIBRE
PHYAD: 0
Transceiver: internal
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
[root@localhost ~]# ethtool -i ens1f0
driver: ice
version: 4.18.0-348.7.1.el8_5.x86_64
firmware-version: 4.50 0x8001d8b6 1.3597.0
expansion-rom-version:
bus-info: 0000:65:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
yuzhang3_intel
I'm sorry, but the issue is outside the scope of the forum. This forum is only focused on Intel Analyzers, like VTune and Advisor.
