Analyzers
5307 Discussions
Intel Vtune Ampilfier memory analysis issue
reddy__Prasanthi
Hi All,
Running code in CRAY XC 40 machine.
When I'm doing memory access getting error at run time
amplxe: Error: This analysis type requires either an access to system-wide monitoring in the Linux perf subsystem or installation of the VTune Amplifier drivers (see the "Sampling Drivers" help topic for further details). Please set the /proc/sys/kernel/perf_event_paranoid value to 0 or less to continue without installing the drivers.
If I change the value in the /proc/sys/kernel/perf_event_paranoid to 0 or less it will effect performance of others who are running jobs in the nodes?
When I'm doing hotsopts analysis it is not giving any error.
Please give me suggestions
Dmitry_R_Intel1
The perf_event_paranoid should not affect performance of other users. It will only have security implications.
ArunJ_Intel
Hi Prasanthi,
Is there anything else we could help you with .
Arun Jose
ArunJ_Intel
Hi Prasanthi,
We are closing this case assuming the solution provided helped
Arun Jose
