Analyzers
5328 Discussions
Internal Error while resolving results file
vjoshi
I have deployed VTune on RH EL 3.0 on 32-bit intel processor. When I try to use callgraph data collection, I get following error:
Sampling works fine. There was no installation error. Callgraph works well for simple applications like ls. I have cleared the cache before running my application. The application that I am trying to profile is a mutli-threaded application which uses CORBA.
Any help in resolving this issue would be greatly appreciated.
Vinay
jeffrey-gallagher
Very interesting report!
I've never seen this before, but, if others have, I'm sure they'll post here.
In the meanwhile, it might be best to open a premier case on this:
In addition to the excellent description you have hear, try to "pack" up the smallest possible project that shows the error, and, attach that .vxp file to the tracker case. (This could speed things up substantially with the analysis.)
Cheers
jdg
Alex_B_Intel
We have a new version out (currently beta and a final version in a couple of weeks). Many such problems were fixed.
Worth to try it on your case.
- Alex.
