Analyzers
5298 Discussions
Invalid access to memory location.
k_sega
Some times ago I've monitored my dll using VTune 7.1. I've generated call graph using static instrumentation without launchable application. Everything were great except error messages that occured sometimes "Data were not collected." or smth like that.The reason of that as I suppose is memory overhead.
Now, I try VTune 9.0. It says "Invalid access to memory location." everytime I try to call LoadLibrary onmy dll.
If it'smatter I have 64-bit workstation with the 32-bit windows server 2003 installed.
What's the problem with the new static instrumentation? Is there any workaround?
If you need additional information to answer - let me know.
Thanks in advance.
