Analyzers
5339 Discussions
Multiple modules with module-filter
Frankie_F_1
I would like to seek clarification to usage of -module-filter option:
inspxe-cl -collect mi2 ... -module-filter module-A,module-B -- <command and arguments>
According to the manual, the above command would report memory errors for both module-A and module-B.
http://software.intel.com/en-us/node/430720
In my environment, the above does not work. It only reports 1 error, instead of a superset of module-A and module-B.
Instead, specifying module-filter multiple times like this worked for me:
inspxe-cl -collect mi2 ... -module-filter module-A -module-filter module-B -- <command and arguments>
I am using Intel Inspector XE 2013 Update 8 on Windows7-x64.
Frankie
Kirill_R_Intel
Hello Frankie,
The comma-separated syntax should work, if there are no spaces. Can you double check that no spaces left between module names? And do you have a sample to share to reproduce the issue?
Kirill
Frankie_F_1
Yes I double-checked. It does not have white-spaces in between. I don't have an sample yet.
I switched to running cases with Inspector-GUI, I picked 2 modules to include as filter. From the 'Command Line...' Dialog, it is actually calling the inspector command-line with this argument:
-module-filter-mode=include -module-filter=[Absolute-Path-To-Module-1] -module-filter=[Absolute-Path-To-Module-2]
So the GUI is not using comma-separated arguments to -module-filter either.
Frankie
Peter_W_Intel
@ Frankie
I tested both, they can work!  For example:
#inspxe-cl -collect mi3 -module-filter-mode=include -module-filter=./primes.icc,/lib64/libpthread.so.0 -- ./primes.icc
#inspxe-cl -collect mi3 -module-filter-mode=include -module-filter=./primes.icc -module-filter=/lib64/libpthread.so.0 -- ./primes.icc
