Analyzers
5340 Discussions
Need help debubuging errors
PIERO87
# SSU Scan Information
Scan Info:
Version:"2.5.0.15"
Date:"12/08/2020"
Time:"00:06:24.7641382"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"ASUSTeK COMPUTER INC."
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends Inc. 3801 , 03/22/2019 12:00 am"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz , GenuineIntel"
Secure Boot State:"On"
SMBIOS Version:"2.7"
Sound Card:"Realtek High Definition Audio"
System Manufacturer:"ASUS"
System Model:"All Series"
System SKU:"All"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "Intel(R) HD Graphics 4600"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1,00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) HD Graphics 4600"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=HD+Graphics+4600"
CoInstallers:"igfxCoIn_v5166.dll, CoDeviceInstall"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmd64.sys"
Driver Date:"08/08/2020 02:00 am"
Driver Path:"C:\Windows\system32\DRIVERS\igdkmd64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"20.19.15.5166"
INF:"oem11.inf"
INF Section:"iHSWD_w10"
Install Date:"Not Available"
Installed Drivers:"igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"11.X"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_0412&SUBSYS_85341043&REV_06\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"59 Hz"
Refresh Rate - Maximum:"60 Hz"
Refresh Rate - Minimum:"50 Hz"
Resolution:"1920 X 1080"
Scan Mode:"Noninterlaced"
Service Name:"igfx"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) HD Graphics Family"
- "Memory"
Physical Memory (Available):"10,72 GB"
Physical Memory (Installed):"16 GB"
Physical Memory (Total):"14,88 GB"
- "BANK 0"
Capacity:"4 GB"
Channel:"ChannelA-DIMM0"
Configured Clock Speed:"1600 MHz"
Configured Voltage:"Not Available"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"Not Available"
Manufacturer:"Micron"
Maximum Voltage:"Not Available"
Memory Type:"DDR3"
Minimum Voltage:"Not Available"
Part Number:"8JTF51264AZ-1G6E1"
Serial Number:"E38774EF"
Status:"Not Available"
Type:"Synchronous"
- "BANK 1"
Capacity:"4 GB"
Channel:"ChannelA-DIMM1"
Form Factor:"DIMM"
Manufacturer:"Hynix/Hyundai"
Memory Type:"DDR3"
Part Number:"HMT451U6AFR8C-PB"
Serial Number:"00550577"
Type:"Synchronous"
- "BANK 2"
Capacity:"4 GB"
Channel:"ChannelB-DIMM0"
Form Factor:"DIMM"
Memory Type:"DDR3"
Part Number:"HMT451U6BFR8A-PB"
Serial Number:"01B105B4"
Type:"Synchronous"
- "BANK 3"
Capacity:"4 GB"
Channel:"ChannelB-DIMM1"
Form Factor:"DIMM"
Memory Type:"DDR3"
Part Number:"HMT451U6BFR8C-PB"
Serial Number:"4F5B70A0"
Type:"Synchronous"
- "Motherboard"
BIOS:"3801, ALASKA - 1072009"
Caption:"Motherboard"
Chipset:"Not Available"
Date:"03/22/2019 02:00 am"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"Q87M-E"
Serial Number:"140932636701497"
Status:"OK"
Version:"Rev X.0x"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Hyper-V Virtual Ethernet Adapter"
Caption:"Hyper-V Virtual Ethernet Adapter"
CoInstallers:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"No"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"VmsProxyHNic.sys"
Driver Date:"06/21/2006 12:00 am"
Driver Path:"C:\Windows\system32\drivers\VmsProxyHNic.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.19041.1"
Index:"0011"
INF:"wvms_mp_windows.inf"
INF Section:"VMSMP.ndi"
Installed:"Yes"
IP Address:"172.18.192.1;fe80::cc56:40b7:64d5:f7ba"
IP Subnet:"255.255.240.0;64"
Last Reset:"12/07/2020 08:07 pm"
MAC Address:"00:15:5D:5E:84:B9"
Manufacturer:"Microsoft"
Media Type:
Net Connection ID:"vEthernet (Ethernet)"
NetCfgInstanceId:"{73A7AD98-A773-4EB1-AE62-E56E31F82C30}"
Number of VLANs:"0"
PNP Device ID:"ROOT\VMS_MP\0000"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Power Management Supported:"No"
Product Type:"Hyper-V Virtual Ethernet Adapter"
Service Name:"VMSNPXYMP"
Status:"Enabled"
Team Name:"Not in a team"
Temperature:
Type:"Ethernet 802.3"
- "Service Bindings"
Bridge Driver:
Client for Microsoft Networks:
File and Printer Sharing for Microsoft Networks:
Internet Protocol Version 4 (TCP/IPv4):
Internet Protocol Version 6 (TCP/IPv6):
Link-Layer Topology Discovery Mapper I/O Driver:
Link-Layer Topology Discovery Responder:
Microsoft LLDP Protocol Driver:
QoS Packet Scheduler:
- "Settings"
*IPChecksumOffloadIPv4:IPv4 Checksum Offload:"Rx & Tx Enabled (3)"
*IPsecOffloadV2:IPSec Offload:"Auth Header and ESP Enabled (3)"
*JumboPacket:Jumbo Packet:"Disabled (1514)"
*LsoV2IPv4:Large Send Offload Version 2 (IPv4):"Enabled (1)"
*LsoV2IPv6:Large Send Offload Version 2 (IPv6):"Enabled (1)"
*MaxRssProcessors:Maximum Number of RSS Processors:"8 (8)"
*NetworkDirect:Network Direct (RDMA):"Disabled (0)"
*NumRSSQueues:Maximum Number of RSS Queues:"8 (8)"
*RscIPv4:Recv Segment Coalescing (IPv4):"Enabled (1)"
*RscIPv6:Recv Segment Coalescing (IPv6):"Enabled (1)"
*RSS:Receive Side Scaling:"Enabled (1)"
*RssBaseProcNumber:RSS Base Processor Number:"0 (0)"
*RssMaxProcNumber:Maximum RSS Processor Number:"63 (63)"
*RSSProfile:RSS Profile:"Closest Processor Static (2)"
*TCPChecksumOffloadIPv4:TCP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
*TCPChecksumOffloadIPv6:TCP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
*UDPChecksumOffloadIPv4:UDP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
*UDPChecksumOffloadIPv6:UDP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
- "Hyper-V Virtual Ethernet Adapter #2"
Caption:"Hyper-V Virtual Ethernet Adapter #2"
DHCP Enabled:"No"
Index:"0012"
Installed:"Yes"
IP Address:"172.29.80.1;fe80::7476:5996:192b:88c5"
MAC Address:"00:15:5D:EB:18:6B"
Media Type:
Net Connection ID:"vEthernet (Default Switch)"
NetCfgInstanceId:"{21DECAA6-2D24-4997-A5CE-613ECACA360B}"
Number of VLANs:"0"
PNP Device ID:"ROOT\VMS_MP\0001"
Status:"Enabled"
Temperature:
Bridge Driver:
- "Settings"
- "Intel(R) Ethernet Connection I217-LM"
- "Caption":"Intel(R) Ethernet Connection I217-LM"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Ethernet+Connection+I217+LM"
Default IP Gateway:"10.0.0.254"
DHCP Enabled:"Yes"
DHCP Lease Expires:"12/09/2020 12:58 pm"
DHCP Lease Obtained:"12/08/2020 12:58 pm"
DHCP Server:"10.0.0.254"
Driver:"e1d68x64.sys"
Driver Date:"08/26/2020 12:00 am"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\e1d68x64.inf_amd64_673d91f6140fdff7\e1d68x64.sys"
Driver Provider:"Intel"
Driver Version:"12.19.0.13"
ETrackID:"Not Available"
Index:"0001"
INF:"oem2.inf"
INF Section:"E153A.10.0.1.19H1"
Installed:"Yes"
IP Address:"10.0.0.156;fe80::b511:73f7:6fe4:bc67"
IP Subnet:"255.255.255.0;64"
MAC Address:"54:A0:50:E8:36:C5"
Manufacturer:"Intel"
Media Type:
Net Connection ID:"Ethernet"
NetCfgInstanceId:"{3139302E-F604-4684-975B-853B42B607C7}"
Number of VLANs:"0"
NVM Version:"Not Available"
Part Number:"FFFFFF-0FF"
PNP Device ID:"PCI\VEN_8086&DEV_153A&SUBSYS_85351043&REV_05\3&11583659&0&C8"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Power Management (Wake On LAN):"Active: Yes, Enable: Yes"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Intel(R) Ethernet Connection I217-LM"
Service Name:"e1dexpress"
Status:"Enabled"
Temperature:
Bridge Driver:
- "Settings"
*FlowControl:Flow Control:"Rx & Tx Enabled (3)"
*InterruptModeration:Interrupt Moderation:"Enabled (1)"
*JumboPacket:Jumbo Packet:"4088 Bytes (4088)"
*LsoV2IPv4:Large Send Offload V2 (IPv4):"Enabled (1)"
*LsoV2IPv6:Large Send Offload V2 (IPv6):"Enabled (1)"
*NumRssQueues:Maximum Number of RSS Queues:"2 Queues (2)"
*PMARPOffload:Protocol ARP Offload:"Enabled (1)"
*PMNSOffload:Protocol NS Offload:"Enabled (1)"
*PriorityVLANTag:Packet Priority & VLAN:"Packet Priority & VLAN Enabled (3)"
*PtpHardwareTimestamp:PTP Hardware Timestamp:"Enabled (1)"
*ReceiveBuffers:Receive Buffers:"256 (256)"
*RSSProfile:RSS load balancing profile:"ClosestProcessor (1)"
*SoftwareTimestamp:Software Timestamp:"RxAll & TxAll (3)"
*SpeedDuplex:Speed & Duplex:"Auto Negotiation (0)"
*TransmitBuffers:Transmit Buffers:"512 (512)"
*WakeOnMagicPacket:Wake on Magic Packet:"Enabled (1)"
*WakeOnPattern:Wake on Pattern Match:"Enabled (1)"
AdaptiveIFS:Adaptive Inter-Frame Spacing:"Enabled (1)"
AutoPowerSaveModeEnabled:Link Speed Battery Saver:"Disabled (0)"
EEELinkAdvertisement:Energy Efficient Ethernet:"Off (0)"
EnablePME:Enable PME:"Enabled (1)"
ITR:Interrupt Moderation Rate:"Adaptive (65535)"
LinkNegotiationProcess:Legacy Switch Compatibility Mode:"Enabled (2)"
LogLinkStateEvent:Log Link State Event:"Disabled (16)"
MasterSlave:Gigabit Master Slave Mode:"Auto Detect (0)"
ReduceSpeedOnPowerDown:Reduce Speed On Power Down:"Disabled (0)"
SipsEnabled:System Idle Power Saver:"Disabled (0)"
WaitAutoNegComplete:Wait for Link:"Auto Detect (2)"
WakeOnLink:Wake on Link Settings:"Forced (2)"
- "Operating System"
.Net Framework Version:"2.0,3.0,3.5,4.0,4.8"
Boot Device:"\Device\HarddiskVolume1"
Internet Browser:"Google Chrome,87.0, Internet Explorer,11.264"
Locale:"United States"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 10 Pro"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"2,25 GB"
Physical Memory (Available):"10,77 GB"
System Directory:"C:\Windows\system32"
Version:"10.0.19041 Build 19041"
Virtual Memory (Available):"10,03 GB"
Virtual Memory (Total):"17,13 GB"
Windows Directory:"C:\Windows"
- "Installed Updates"
KB2151757:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [2020/11/08]"
KB2151757:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [2020/11/08]"
KB2467173:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [2020/11/08]"
KB2467173:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [2020/11/08]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB4537759:"Security Update [11/8/2020]"
KB4557968:"Security Update [11/8/2020]"
KB4580325:"Security Update [11/24/2020]"
KB4580419:"Update [11/24/2020]"
KB982573:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [2020/11/08]"
KB982573:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [2020/11/08]"
SP1:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [Not Available]"
SP1:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [Not Available]"
- "Processor"
- "Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 60 Stepping 3"
- "Chipset Name":"Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Core+i7+4790+CPU+"
CPU Speed:"3,6 GHz"
Current Voltage:"1.8 volts"
Driver:"Not Available"
Driver Date:"04/21/2009 12:00 am"
Driver Path:"C:\Windows\system32\drivers\intelppm.sys"
Ext. Family:"Not Available"
Family:"Intel Core™ i7-2760QM"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"4 x 256 KB"
Level 2 Cache:"4 x 1024 KB"
Level 3 Cache:"8 MB"
Load:"8%"
Manufacturer:"GenuineIntel"
Model:"60"
Name:"Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz"
Number of Cores:"4"
Number of Cores Enabled:"4"
Number of Logical Processors:"8"
Part Number:"Fill By OEM"
Processor ID:"BFEBFBFF000306C3"
Revision:"15363"
Serial Number:"Not Available"
Service Name:"intelppm"
Status:"OK"
Stepping:"3"
- "Storage"
- "TOSHIBA MQ04ABF100"
Capablities:"Random Access, Supports Writing, SMART Notification"
Caption:"TOSHIBA MQ04ABF100"
Cylinder - Total:"121601"
Description:"Disk drive"
Error Code:"Device is working properly"
Firmware Revision:"1J"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Interface Type:"SCSI"
Manufacturer:"(Standard disk drives)"
Model:"TOSHIBA MQ04ABF100"
Partitions:"3"
PNP Device ID:"SCSI\DISK&VEN_ATA&PROD_TOSHIBA_MQ04ABF1\4&E937C7&0&010000"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
SCSI Bus:"1"
SCSI LUN:"0"
SCSI Port:"0"
Sectors - Per Track:"63"
Sectors - Total:"1953520065"
Serial Number:"99RAP3YST"
Size – Available:"311,83 GB"
SMART Attributes:"Self-Test: 174 minutes, OK, Short Self-Test: 2 minutes, OK"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"31008255"
- "C:"
Availability:"Not Available"
Caption:"C:"
Compression Method:"Not Compressed"
Description:"Local Fixed Disk"
File System:"NTFS"
Name:"Not Available"
Serial Number:"0809C84D"
Size – Available:"306,83922958374 GB"
Volume Dirty:"No"
- "SMART"
0x01 Raw Read Error Rate:0:"50"
0x02 Throughput Performance:0:"50"
0x03 Spin Up Time:1243:"1"
0x04 Start/Stop Count:10595:"0"
0x05 Reallocated Sector Count:0:"50"
0x07 Seek Error Rate:0:"50"
0x08 Seek Timer Performance:0:"50"
0x09 Power-On Hours:4839:"0"
0x0A Spin Retry Count:0:"30"
0x0C Power Cycle Count:1334:"0"
0xBF G-sense Rate/Servo Tracking:413:"0"
0xC0 Unsafe Shutdown Count:221:"0"
0xC1 Load/Unload Cycle Count:35949:"0"
0xC2 Internal Device Temperature:35° C:"0"
0xC4 Reallocation Count:0:"0"
0xC5 Current Pending Errors Count:0:"0"
0xC6 Uncorrectable Sector Count:0:"0"
0xC7 CRC Error Count:57:"0"
0xDC Disk Shift:0:"0"
0xDE Loaded Hours:4344:"0"
0xDF Load/Unload Retry Count:0:"0"
0xE0 Load Friction:0:"0"
0xE2 Timed Workload – Media Wear:271:"0"
0xF0 Head Flying Hours:0:"1"
...#SSU#...
#Logs#System Messages#Included
The Microsoft Office Click-to-Run Service service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 0 milliseconds: Restart the service.
The Remote Procedure Call (RPC) Locator service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 120000 milliseconds: Restart the service.
The Still Image Acquisition Events service terminated with the following service-specific error:
The remote procedure call failed.
The Hyper-V Time Synchronization Service service depends on the Microsoft Hyper-V Guest Infrastructure Driver service which failed to start because of the following error:
A device attached to the system is not functioning.
The Microsoft Hyper-V Guest Infrastructure Driver service failed to start due to the following error:
The Intel(R) Driver & Support Assistant Updater service terminated unexpectedly. It has done this 1 time(s).
The Intel(R) Driver & Support Assistant service terminated unexpectedly. It has done this 1 time(s).
A fatal error occurred while creating a TLS client credential. The internal error state is 10013.
A timeout (30000 milliseconds) was reached while waiting for a transaction response from the hvsics service.
The Intel(R) TPM Provisioning Service service terminated with the following error:
The handle is invalid.
The NetTcpActivator service depends on the NetTcpPortSharing service which failed to start because of the following error:
The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
Failed to create System Volume Information folder on evice\HarddiskVolume7.
The default transaction resource manager on volume E: encountered a non-retryable error and could not start. The data contains the error code.
The server {AB8902B4-09CA-4BB6-B78D-A8F59079A8D5} did not register with DCOM within the required timeout.
The User Data Access_52e6ec service terminated with the following error:
Class not registered
The server {9A4948D9-13FC-4FAC-B60A-FBA6EE0FB11C} did not register with DCOM within the required timeout.
...#SSU#...
#Logs#Direct-X Diagnostics#No Log
An unexpected error occurred while attempting to execute DxDiag.exe
...#SSU#...
Gopika_Intel
Thank you for posting in the Analysers forum. Could you please share us with the
  1. Details of the analyser you are using(vtune profiler or advisor)
  2. Version of the analyser
  3. Detail of the analysis done
  4. Operating system and its version
  5. Details of the application
  6. A reproducer code
  7. Steps to reproduce the error
Gopika
Gopika_Intel
We haven’t heard back from you, was the error resolved? Let us know your updates.
Gopika
Gopika_Intel
Hi
We haven’t heard back from you. We won’t be monitoring this thread. For further issues and queries, please start a new thread.
Gopika
