Analyzers
5275 Discussions
OneAPI 2021.1.1 Gold Vtune command line tool doesn't work for non-root users
Lin_L_Intel
Command: vtune -collect hotspots -data-limit=0 -finalization-mode=none -result-dir="sample" -no-summary ls
When executing it under non-root user, it runs vtune but doesn't invoke ls command(no collect data). Run with root user, it works fine.
Non-root user is already in group " video render vtune".
Are there any other settings?
RaeesaM_Intel
Thank you for your patience.
Looks like the known issue is with permissions for not-root users from VTune sw-based hotspots analysis on systems where installation was run by root/sudo.
To check exec permissions :
In the <vtune_install_dir>/bin64 directory , Run
$ ls -l | grep pinbin
To fix permissions:
$ sudo chmod o+rx <vtune_install_dir>/bin64/pinbin
Hope this helps.
Raeesa
RaeesaM_Intel
Thank you for posting in Intel VTune Profiler Forum.
We couldn't reproduce the issue from our end.
Could you please run the self-checker script ,
./<vtune-installation-directory>/bin64/vtune-self-checker.sh
See whether its working fine and share the log.
Also, please attach the entire result folder after running the vtune command :
Raeesa
Lin_L_Intel
vtune-self-checker.sh  shows failure for
Instrumentation based analysis check
Example of analysis types: Hotspots with default knob sampling-mode=sw, Threading with default knob sampling-and-waits=sw
Collection: Fail
Log and entire result folder after running the vtune command are attached.
RaeesaM_Intel
We are discussing this issue with concerned team internally. We will get back to you on the updates.
Raeesa
RaeesaM_Intel
To fix permissions:
Hope this helps.
Raeesa
RaeesaM_Intel
Thank you for accepting the solution. We are discontinuing monitoring this thread . Please raise a new thread incase of any further issues. We would be happy to help you out .
Raeesa
Ekaterina_L_Intel
