Analyzers
5317 Discussions
OneAPI 2024.0.0 modulefiles/vtune/{2024.0,latest} bug
CFR
New Contributor II
I think:
set scriptpath ""
set scriptpath "[file dirname [file normalize "/___"]]"
is supposed to be:
set scriptpath "${ModulesCurrentModulefile}"
set scriptpath "[file dirname [file normalize "$scriptpath/___"]]"
SreedeviK_Intel
Thank you for posting in Intel communities.
We were able to reproduce the issue from our end on linux machine with latest version of VTune (2024.0).
We are checking on it internally and will get back to you with an update shortly.
Could you please share your OS and hardware details?
Sreedevi
CFR
New Contributor II
The install was done on a CentOS 7.9, Xeon E5-2637 machine.
SreedeviK_Intel
Thanks for reporting this issue.
We were able to reproduce it and we have informed the development team about it.
Sreedevi
nmnobre
Hi, both the current and patched modules have unbalanced curly braces in:
set modulefilever "[file tail "$scriptpath}"]"
Cheers,
Nuno
Jeffrey_R_Intel1
Thank you for reporting this. The Intel(R) VTune(TM) Profiler module file has been fixed in the 2024.2 release.
CFR
New Contributor II
Sadly it looks like 2024.02 is broke in a different way...
set script_path "[file normalize [exec readlink -f ${ModulesCurrentModulefile}]]"
...results is something like...
<installdir>/vtune/2024.2/etc/modulefiles/vtune/2024.2
and then...
set PRODUCT_INSTALL_DIR "[file dirname [file dirname $script_path]]"
... turns into ...
What's missing is something that takes off two more level of directories...
set PRODUCT_INSTALL_DIR "[file dirname [file dirname $PRODUCT_INSTALL_DIR]]"
... to get a PRODUCT_INSTALL_DIR to point at the right level...
 (At least that's what I had to do....)
yuzhang3_intel
This is one known issue, which will be fixed in a future release. Here is a workaround:
The target file is something like /opt/intel/oneapi/vtune/latest/etc/modulefiles/vtune/2024XX
set write permissions on the target file and edit the file
Old
New
set PRODUCT_INSTALL_DIR "[file dirname [file dirname [file dirname [file dirname $script_path]]]]"
Open a new shell and load the module again
