Analyzers
5337 Discussions
Problem (installing)running VTune(TM) Performance Analyzer 9.1p for Linux*
masterdot
I have some problems installing and running VTune Performance Analyzer 9.1p for Linux* (Build 102)
on a Suse SLES 10 (kernel 2.6.16.60-0.23-smp) and a Intel Xeon CPU E5450.
During installation (typical) of the evaluation version, I get the following two suspicious errormessages (I dont know if any of these are relevant to my problem of not beeing able to run vtune):
/etc/init.d/ntd: NT daemon status: ..done
/etc/init.d/ntd: Create /opt/sag/exx/v721/etc/dcomconfig
/etc/init.d/ntd: # --------------------------------------------
ntd 0:off 1:off 2:off 3:off 4:off 5:off 6:off
insserv: Service ypbind has to be enabled for service ntd
insserv: exiting now!
/sbin/insserv failed, exit code 1
and:
Wed Oct 15 13:07:12: 'intel-vtune-doc-9.1p-102.rpm' installed
Failed to load library /opt/intel/vtune/shared/bin/libStandardExeCtrl.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGExeCtrlTLB.so
Failed to load library /opt/intel/vtune/analyzer/bin/libStandaloneViewers.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGCons4VTUIEc.so
Failed to load library /opt/intel/vtune/analyzer/bin/libSplStandaloneViewAddin.so
Failed to load library /opt/intel/vtune/shared/bin/libFileDialogEc.so
Failed to load library /opt/intel/vtune/analyzer/bin/libRatiosEditor.so
Failed to load library /opt/intel/vtune/shared/bin/libReportsEc.so
Failed to load library /opt/intel/vtune/analyzer/bin/libtebscollectorps.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGAddin.so
Failed to load library /opt/intel/vtune/shared/bin/libShellTLB.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGC_TLB.so
Failed to load library /opt/intel/vtune/analyzer/bin/libSVAddin.so
Failed to load library /opt/intel/vtune/analyzer/bin/libSamplingCLAddin.so
Failed to load library /opt/intel/vtune/shared/bin/libComInfo.so
Failed to load library /opt/intel/vtune/shared/bin/libActivity.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGC_GUI_TLBps.so
Failed to load library /opt/intel/vtune/analyzer/bin/libMiniDE.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGTextConsumer.so
Failed to load library /opt/intel/vtune/shared/bin/libWorkspaceMgr.so
Failed to load library /opt/intel/vtune/analyzer/bin/libtebsproxyexecontroller.so
Failed to load library /opt/intel/vtune/shared/bin/libFileMgr.so
Failed to load library /opt/intel/vtune/analyzer/bin/libSVConsumerEcClient.so
Failed to load library /opt/intel/vtune/analyzer/bin/libSamplingConsumerEc.so
Failed to load library /opt/intel/vtune/shared/bin/libActivityps.so
Failed to load library /opt/intel/vtune/shared/bin/libEnvInfops.so
Failed to load library /opt/intel/vtune/analyzer/bin/libSamplingImporter.so
Failed to load library /opt/intel/vtune/shared/bin/libVTRun.so
Failed to load library /opt/intel/vtune/analyzer/bin/libVTMHDialogs.so
Failed to load library /opt/intel/vtune/analyzer/bin/libATLBistroController.so
Failed to load library /opt/intel/vtune/analyzer/bin/libATLBistroControllerTLBps.so
Failed to load library /opt/intel/vtune/analyzer/bin/libVTMHPrefPagesEc.so
Failed to load library /opt/intel/vtune/shared/bin/libRunCfg.so
Failed to load library /opt/intel/vtune/analyzer/bin/libModuleHandler.so
Failed to load library /opt/intel/vtune/shared/bin/libRunCfgps.so
Failed to load library /opt/intel/vtune/shared/bin/ProjectNavigator.tlb
Failed to load library /opt/intel/vtune/shared/bin/libWorkspaceUI.so
Failed to load library /opt/intel/vtune/shared/bin/libDataObjectps.so
Failed to load library /opt/intel/vtune/shared/bin/libWorkspaceMgrEc.so
*SNIP* goes on for quite a while!
Failed to load library /opt/intel/vtune/shared/bin/libvtlHandlers.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGC_L2L.so
Failed to load library /opt/intel/vtune/shared/bin/libComInfops.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGPackNGo.so
Failed to load library /opt/intel/vtune/analyzer/bin/libSamplingWizardLogic.so
Failed to load library /opt/intel/vtune/analyzer/bin/libSOTAccess.so
Failed to load library /opt/intel/vtune/shared/bin/libFileSearchAddIn.so
Wed Oct 15 13:07:14: Directory for global data was set to /opt/intel/vtune/global_data
Wed Oct 15 13:07:17: Wrappers have been configured.
Wed Oct 15 13:07:24: Starting Eclipse installation..
Wed Oct 15 13:07:27: Eclipse installation finished.
Wed Oct 15 13:12:17: The Intel VTune Performance Analyzer 9.1 for Linux* (full install) was successfully installed.
So the installer tells me it is installed successfully, but if I try to run vtl or vtlec, I get the following errormessage:
The EntireX (aka 'ntd') service, required by VTune Analyzer, is not running.
As root, please start the 'ntd' service with the following command:
/etc/init.d/ntd restart
But after restarting the ntd service (when I restart the ntd service, it says ... done, no errormessage) vtl and vtlec throw exactly the same errormessage.
Does anybody have any idea what could be wrong?
Thanks for any help,
Dennis
Peter_W_Intel
I doubt you NTD or other VTune Analyzer's components were not uninstalled successfully before your installing new update product.
So I suggest you to uninstall prior product first, then check -
1) "/etc/init.d/ntd stop", "/etc/init.d/ntd deinstall" (if ntd still is alive)
2) You has to check if still has VTune compoents remained in the system after uninstalling the product
a) Use rpm to query if there are : intel-vdk*, intel-vtune*, dcom in the system
b) Use rpm to erase them if have.
3. Re-install the product update.
Regards, Peter
masterdot
thanks for your reply.
Unfortunately this didnt solve the problem. Since the problem existed during first installation on this machine too, I doubt it has anything to do with the unistall.
However during testing your approach, I noticed something strange:
Error: NTD is not running at the moment, please start it before using NT services.
ntwopper -v -g vtunesag -u vtunesag ntd
1 NTD 1.0(retail), made at 2007-09-18 08:00 with crypto support, build 124157, pid 25577, shm size 768 starting...
2
3 ERROR: EntireX DCOM license check error!
4 The EntireX XML license key file can not be found.
5 Please check your license file at:
6 /opt/sag/common/LKey/exx721.xml
Google helped me with this problem, the file permissions for the licence file were wrong.
After changeing these, I got a new error when trying to start vtl:
/opt/intel/vtune/bin/vtl
Error 0x80040154: Unable to load some components. Make sure user data directory contains enough disk space.
Disk space on the machine is no problem, and I didnt find anything about that error anywhere.
Do you have another clue for me?
Dennis
Peter_W_Intel
File permission for license file? I assume that you installed the product under "root" user.
1. Can you do "/etc/init.d/ntd restart" to ensure dcom is working?
[root@conroe-em64t ~]# /etc/init.d/ntd restart
18:21:57 17-10-08 /etc/init.d/ntd: restart
chown: `sag:sag': invalid user
18:21:57 17-10-08 /etc/init.d/ntd: Shutting down NT daemon... sermon shut
18:21:58 17-10-08 /etc/init.d/ntd: ntd is running down. Waiting...
18:22:12 17-10-08 /etc/init.d/ntd: NT daemon status: down
18:22:12 17-10-08 /etc/init.d/ntd: Starting NT daemon: ntwopper -v -g vtunesag -u vtunesag ntd
18:22:13 17-10-08 /etc/init.d/ntd: NT daemon status: running
2. Check if all VTune components are installed -
[root@conroe-em64t doc]# rpm -qa intel-vtune*
intel-vtune-rdc_runtimelibs-9.1p-102
intel-vtune-rdc_core-9.1p-102
intel-vtune-runtimelibs-9.1p-102
intel-vtune-rdc_common-9.1p-102
intel-vtune-core-9.1p-102
[root@conroe-em64t doc]# rpm -qa intel-vdk*
intel-vdk-src-4.1-102
intel-vdk-4.1-102
Also you can review /var/log/vtune_install.log to know if you succeed to install the product
3. Ensure vtune driver is loaded,
[root@conroe-em64t ~]# /etc/init.d/vtune status
Checking if the VTune analyzer sampling driver is loaded ... YES.
Otherwise, you should go /opt/intel/vtune/vdk/src/doc to read HOWTO-BUILD-VTUNE-DRIVER
If you have no problem on above, then you should have no problem to run vtl.
Regards, Peter
masterdot
intel-vdk-4.1-102
Regards, Peter
I've checked all that, and everything is just like you already posted. So it seems to me as if vtune should be installed correctly.
But when I try to run vtl I still get the same message:
> ./vtl
But there is enough disc space available:
> df /opt/intel/vtune/global_data/
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/mapper/vg1-lvopt1
25702268 3979908 20416760 17% /opt
I really have no idea how I could possibly fix that...
Any ideas left?
Dennis
tangouniform
I had a similar problem where I did not have permissions to write to gobal_data. I set the VTUNE_GLOBAL_DATA in my env to something else and am able to run. If you have root, you may just want to adjust your permissions if need be.
TimP
Quoting - tangouniform
If you set up VTune successfully and add your account to the specified group (default vtune), you should not have difficulties with permissions.
Peter_W_Intel
Quoting - masterdot
> ./vtl
Any ideas left?
Dennis
I strongly suggest you to uninstall/reinstall the product - (I saw /dev/mapper/vg1-lvopt1)
If you are installing the vtl software on a network file system (such as NFS or AFS), you may experience security-related installation failures, you should first install the needed software local driver.
Please use "root" user to install the product on local driver - check "fdisk -l"
inkant
I am also having the same trouble with the installation. Also that uninstalling and reinstalling also gives the same problem. I have used the vtune 9.1 with latest update. This is the output of fdisk.
[root@vivekananda vtune_linux_9.1]# fdisk -l /opt/intel
last_lba(): I don't know how to handle files with mode 41ed
techtalk
Quoting - masterdot
and:
Dennis
I am having the same problem where it says
chown : invalid user :sag sag
techtalk
Quoting - inkant
I get the same error on fdisk
techtalk
Quoting - tim18
I booted up linux now in run level 3. How do I do whats suggested in the fix above.
techtalk
intel-vdk-4.1-102
Regards, Peter
I tried all the experiments described in the quote above. I get the same results as described above. My log file does say that VTUNE is installed successfully.
zmi007
The same problem:
Installation is complete:
Thank you for using Intel Software Development Products, tools for improving application performance.
#/etc/init.d/ntd status
16:05:04 17-03-10 /etc/init.d/ntd: status
chown: invalid user: `sag:sag'
running
>./vtl
Error 0x800706ba: Unable to load some components. Make sure user data directory contains enough disk space.
./vtlec
JVM terminated. Exit code=1
/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/bin/java
-Dosgi.splashLocation=/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/com.intel.sdp.primary_2.0.4/splash.bmp
-Dosgi.sharedConfiguration.area=/opt/intel/vtune/bin/../shared/eclipse/configuration
-jar /opt/intel/eclipsepackage/3.2.1/eclipse/startup.jar
-os linux
-ws gtk
-arch x86
-launcher /opt/intel/eclipsepackage/3.2.1/eclipse/eclipse
-name Eclipse
-showsplash 600
-exitdata 96000b
-product com.intel.sdp.primary.product
-perspective com.intel.vtune.shell.tuningPerspective
-vm /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/bin/java
-vmargs
zmi007
ok, I solved my problem by using:
"Use single Group ID [ on ]"
and
"3. VTune analyzer group [ use group 'users' ]"
during installation
Now the programs (vtl and vtlec) start and work correctly.
miklos_klaar
Hi Peter,
I'm having the same trouble with the version of vTune that I downloaded today. This is my second try installing as root - I deinstalled in between.
uname -a:
Ubuntu 9.04
Linux tesla 2.6.32.8-opto2 #1 SMP Tue Feb 23 06:58:05 PST 2010 x86_64 GNU/Linux
When I try to install vtune I get:
The Intel VTune Performance Analyzer 9.1 for Linux* (full install) is being installed...
Please wait ...
EntireX DCOM for Linux* component is being installed...
EntireX DCOM for Linux* component was successfully installed.
The VTune Performance Analyzer Driver Kit component is being installed...
Searching a pre-built driver ... FAILED
Building the driver for your kernel ... OK
Installing sampling driver boot script ... OK
Loading the driver ... OK
The VTune Performance Analyzer Driver Kit component was successfully installed.
The VTune Performance Analyzer Remote Agent component is being installed...
The VTune Performance Analyzer Remote Agent component was successfully installed.
The VTune Performance Analyzer component is being installed...
/opt/intel/vtune/.scripts/POSTIN.intel-vtune-core: line 598: /opt/intel/vtune/analyzer/bin/instsupp: cannot execute binary file
/opt/intel/vtune/.scripts/POSTIN.intel-vtune-core: line 603: /opt/intel/vtune/analyzer/bin/instsupp-ec: cannot execute binary file
/opt/intel/vtune/.scripts/POSTIN.intel-vtune-core: line 608: /opt/intel/vtune/shared/bin/instsupp: cannot execute binary file
/opt/intel/vtune/.scripts/POSTIN.intel-vtune-core: line 613: /opt/intel/vtune/shared/bin/instsupp-ec: cannot execute binary file
The VTune Performance Analyzer component was successfully installed.
The Eclipse component is being installed...
The Eclipse component was successfully installed.
INSTALLATION WARNINGS
Intel VTune Performance Analyzer 9.1 for Linux* installation
WARNING: Checking if a pre-built sampling driver exists for your kernel ... no.
WARNING:
Failed to load library /opt/intel/vtune/analyzer/bin/libDBMgr.so
Failed to load library /opt/intel/vtune/analyzer/bin/libSVTextConsumer.so
Failed to load library /opt/intel/vtune/shared/bin/libActivityHps.so
Failed to load library /opt/intel/vtune/shared/bin/libReportsps.so
Failed to load library /opt/intel/vtune/analyzer/bin/libSamplingPreferencesPagesEc.so
Failed to load library /opt/intel/vtune/analyzer/bin/libOptrepAddin.so
Failed to load library /opt/intel/vtune/analyzer/bin/libvtremoteconnectorps.so
Failed to load library /opt/intel/vtune/shared/bin/libDataObject.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGImpExp.so
Failed to load library /opt/intel/vtune/shared/bin/FileSearchAddIn.tlb
Failed to load library /opt/intel/vtune/shared/bin/libFileDialogps.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGExeCtrl_L2L.so
Failed to load library /opt/intel/vtune/shared/bin/libProductInfo.so
Failed to load library /opt/intel/vtune/analyzer/bin/libSamplingCLConsumer.so
Failed to load library /opt/intel/vtune/shared/bin/libReports.so
Failed to load library /opt/intel/vtune/analyzer/bin/libAnPropContainers.so
Failed to load library /opt/intel/vtune/shared/bin/libEcGUIClient.so
Failed to load library /opt/intel/vtune/shared/bin/libVTRunEc.so
Failed to load library /opt/intel/vtune/shared/bin/libTuningBrowser.so
Failed to load library /opt/intel/vtune/shared/bin/libFileCopier.so
Failed to load library /opt/intel/vtune/shared/bin/libEnvInfo.so
Failed to load library /opt/intel/vtune/shared/bin/libCollection.so
Failed to load library /opt/intel/vtune/shared/bin/libWorkspaceMgrps.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGC_TLBps.so
Failed to load library /opt/intel/vtune/shared/bin/libism_2.so
Failed to load library /opt/intel/vtune/analyzer/bin/libtebscollector.so
Failed to load library /opt/intel/vtune/analyzer/bin/libMiniDEProxy.so
Failed to load library /opt/intel/vtune/analyzer/bin/libAnProdInfo.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGCons4VT.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGExeCtrl.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGC_GUI_TLB.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGWizardEc.so
Failed to load library /opt/intel/vtune/shared/bin/libPropBag.so
Failed to load library /opt/intel/vtune/shared/bin/libShellps.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGC.so
Failed to load library /opt/intel/vtune/analyzer/bin/libtebscollectorEc.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGC_Ec.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGPreferencePagesEC.so
Failed to load library /opt/intel/vtune/shared/bin/libFileCopierps.so
Failed to load library /opt/intel/vtune/shared/bin/libActivityEc.so
Failed to load library /opt/intel/vtune/analyzer/bin/libAnalyzerWizardsAddin.so
Failed to load library /opt/intel/vtune/analyzer/bin/libEcAnalyzerUtils.so
Failed to load library /opt/intel/vtune/analyzer/bin/libSamplingPropContainersEc.so
Failed to load library /opt/intel/vtune/analyzer/bin/libRatios.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGWizardLogic.so
Failed to load library /opt/intel/vtune/analyzer/bin/libATLBistroControllerTLB.so
Failed to load library /opt/intel/vtune/shared/bin/libShell.so
Failed to load library /opt/intel/vtune/shared/bin/libVTRunps.so
Failed to load library /opt/intel/vtune/shared/bin/libFileSearchPrefPagesEc.so
Failed to load library /opt/intel/vtune/analyzer/bin/libSVConsumerEc.so
Failed to load library /opt/intel/vtune/shared/bin/libFileDialog.so
Failed to load library /opt/intel/vtune/analyzer/bin/libATLBistroController_L2L.so
Failed to load library /opt/intel/vtune/analyzer/bin/libSVPreferencePagesEC.so
Failed to load library /opt/intel/vtune/analyzer/bin/libSamplingConsumerEcClient.so
Failed to load library /opt/intel/vtune/analyzer/bin/libvtremoteconnector.so
Failed to load library /opt/intel/vtune/analyzer/bin/libVTFormulaEngine.so
Failed to load library /opt/intel/vtune/analyzer/bin/libCGExeCtrlTLBps.so
Failed to load library /opt/intel/vtune/analyzer/bin/libSamplingWizardEc.so
Failed to load library /opt/intel/vtune/shared/bin/libZLibComponent.so
The VTune Performance Analyzer 9.1 for Linux* may work incorrectly.
Press to continue.
INSTALLATION NOTES
Note: You need to be a member of the "users" group
in order to use the VTune Performance Analyzer.
Note: To invoke the VTune Performance Analyzer, run
"/opt/intel/vtune/bin/vtl" for command line
and "/opt/intel/vtune/bin/vtlec" to start
the VTune Performance Analyzer within Eclipse.
Note: To uninstall the VTune Performance Analyzer 9.1 for Linux*
please run "/opt/intel/vtune/bin/uninstall_vtune.sh" file.
Press .
Please wait ...
------------------------------------------------------------EntireX DCOM for Linux* component is being installed...EntireX DCOM for Linux* component was successfully installed.------------------------------------------------------------------------------------------------------------------------The VTune Performance Analyzer Driver Kit component is being installed...Searching a pre-built driver ... FAILEDBuilding the driver for your kernel ... OKInstalling sampling driver boot script ... OKLoading the driver ... OKThe VTune Performance Analyzer Driver Kit component was successfully installed.------------------------------------------------------------------------------------------------------------------------The VTune Performance Analyzer Remote Agent component is being installed...The VTune Performance Analyzer Remote Agent component was successfully installed.------------------------------------------------------------------------------------------------------------------------The VTune Performance Analyzer component is being installed..
./opt/intel/vtune/.scripts/POSTIN.intel-vtune-core: line 598: /opt/intel/vtune/analyzer/bin/instsupp: cannot execute binary file/opt/intel/vtune/.scripts/POSTIN.intel-vtune-core:
line 603: /opt/intel/vtune/analyzer/bin/instsupp-ec: cannot execute binary file/opt/intel/vtune/.scripts/POSTIN.intel-vtune-core: line 608: /opt/intel/vtune/shared/bin/instsupp: cannot execute binary file/opt/intel/vtune/.scripts/POSTIN.intel-vtune-core: line 613: /opt/intel/vtune/shared/bin/instsupp-ec: cannot execute binary fileThe VTune Performance Analyzer component was successfully installed.------------------------------------------------------------------------------------------------------------------------The Eclipse component is being installed...The Eclipse component was successfully installed.------------------------------------------------------------
===============================================================================INSTALLATION WARNINGS
Intel VTune Performance Analyzer 9.1 for Linux* installation-------------------------------------------------------------------------------
WARNING:Failed to load library /opt/intel/vtune/shared/bin/libStandardExeCtrl.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGExeCtrlTLB.soFailed to load library /opt/intel/vtune/analyzer/bin/libStandaloneViewers.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGCons4VTUIEc.soFailed to load library /opt/intel/vtune/analyzer/bin/libSplStandaloneViewAddin.soFailed to load library /opt/intel/vtune/shared/bin/libFileDialogEc.soFailed to load library /opt/intel/vtune/analyzer/bin/libRatiosEditor.soFailed to load library /opt/intel/vtune/shared/bin/libReportsEc.soFailed to load library /opt/intel/vtune/analyzer/bin/libtebscollectorps.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGAddin.soFailed to load library /opt/intel/vtune/shared/bin/libShellTLB.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGC_TLB.soFailed to load library /opt/intel/vtune/analyzer/bin/libSVAddin.soFailed to load library /opt/intel/vtune/analyzer/bin/libSamplingCLAddin.soFailed to load library /opt/intel/vtune/shared/bin/libComInfo.soFailed to load library /opt/intel/vtune/shared/bin/libActivity.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGC_GUI_TLBps.soFailed to load library /opt/intel/vtune/analyzer/bin/libMiniDE.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGTextConsumer.soFailed to load library /opt/intel/vtune/shared/bin/libWorkspaceMgr.soFailed to load library /opt/intel/vtune/analyzer/bin/libtebsproxyexecontroller.soFailed to load library /opt/intel/vtune/shared/bin/libFileMgr.soFailed to load library /opt/intel/vtune/analyzer/bin/libSVConsumerEcClient.soFailed to load library /opt/intel/vtune/analyzer/bin/libSamplingConsumerEc.soFailed to load library /opt/intel/vtune/shared/bin/libActivityps.soFailed to load library /opt/intel/vtune/shared/bin/libEnvInfops.soFailed to load library /opt/intel/vtune/analyzer/bin/libSamplingImporter.soFailed to load library /opt/intel/vtune/shared/bin/libVTRun.soFailed to load library /opt/intel/vtune/analyzer/bin/libVTMHDialogs.soFailed to load library /opt/intel/vtune/analyzer/bin/libATLBistroController.soFailed to load library /opt/intel/vtune/analyzer/bin/libATLBistroControllerTLBps.soFailed to load library /opt/intel/vtune/analyzer/bin/libVTMHPrefPagesEc.soFailed to load library /opt/intel/vtune/shared/bin/libRunCfg.soFailed to load library /opt/intel/vtune/analyzer/bin/libModuleHandler.soFailed to load library /opt/intel/vtune/shared/bin/libRunCfgps.soFailed to load library /opt/intel/vtune/shared/bin/ProjectNavigator.tlbFailed to load library /opt/intel/vtune/shared/bin/libWorkspaceUI.soFailed to load library /opt/intel/vtune/shared/bin/libDataObjectps.soFailed to load library /opt/intel/vtune/shared/bin/libWorkspaceMgrEc.soFailed to load library /opt/intel/vtune/analyzer/bin/libDBMgr.soFailed to load library /opt/intel/vtune/analyzer/bin/libSVTextConsumer.soFailed to load library /opt/intel/vtune/shared/bin/libActivityHps.soFailed to load library /opt/intel/vtune/shared/bin/libReportsps.soFailed to load library /opt/intel/vtune/analyzer/bin/libSamplingPreferencesPagesEc.soFailed to load library /opt/intel/vtune/analyzer/bin/libOptrepAddin.soFailed to load library /opt/intel/vtune/analyzer/bin/libvtremoteconnectorps.soFailed to load library /opt/intel/vtune/shared/bin/libDataObject.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGImpExp.soFailed to load library /opt/intel/vtune/shared/bin/FileSearchAddIn.tlbFailed to load library /opt/intel/vtune/shared/bin/libFileDialogps.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGExeCtrl_L2L.soFailed to load library /opt/intel/vtune/shared/bin/libProductInfo.soFailed to load library /opt/intel/vtune/analyzer/bin/libSamplingCLConsumer.soFailed to load library /opt/intel/vtune/shared/bin/libReports.soFailed to load library /opt/intel/vtune/analyzer/bin/libAnPropContainers.soFailed to load library /opt/intel/vtune/shared/bin/libEcGUIClient.soFailed to load library /opt/intel/vtune/shared/bin/libVTRunEc.soFailed to load library /opt/intel/vtune/shared/bin/libTuningBrowser.soFailed to load library /opt/intel/vtune/shared/bin/libFileCopier.soFailed to load library /opt/intel/vtune/shared/bin/libEnvInfo.soFailed to load library /opt/intel/vtune/shared/bin/libCollection.soFailed to load library /opt/intel/vtune/shared/bin/libWorkspaceMgrps.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGC_TLBps.soFailed to load library /opt/intel/vtune/shared/bin/libism_2.soFailed to load library /opt/intel/vtune/analyzer/bin/libtebscollector.soFailed to load library /opt/intel/vtune/analyzer/bin/libMiniDEProxy.soFailed to load library /opt/intel/vtune/analyzer/bin/libAnProdInfo.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGCons4VT.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGExeCtrl.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGC_GUI_TLB.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGWizardEc.soFailed to load library /opt/intel/vtune/shared/bin/libPropBag.soFailed to load library /opt/intel/vtune/shared/bin/libShellps.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGC.soFailed to load library /opt/intel/vtune/analyzer/bin/libtebscollectorEc.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGC_Ec.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGPreferencePagesEC.soFailed to load library /opt/intel/vtune/shared/bin/libFileCopierps.soFailed to load library /opt/intel/vtune/shared/bin/libActivityEc.soFailed to load library /opt/intel/vtune/analyzer/bin/libAnalyzerWizardsAddin.soFailed to load library /opt/intel/vtune/analyzer/bin/libEcAnalyzerUtils.soFailed to load library /opt/intel/vtune/analyzer/bin/libSamplingPropContainersEc.soFailed to load library /opt/intel/vtune/analyzer/bin/libRatios.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGWizardLogic.soFailed to load library /opt/intel/vtune/analyzer/bin/libATLBistroControllerTLB.soFailed to load library /opt/intel/vtune/shared/bin/libShell.soFailed to load library /opt/intel/vtune/shared/bin/libVTRunps.soFailed to load library /opt/intel/vtune/shared/bin/libFileSearchPrefPagesEc.soFailed to load library /opt/intel/vtune/analyzer/bin/libSVConsumerEc.soFailed to load library /opt/intel/vtune/shared/bin/libFileDialog.soFailed to load library /opt/intel/vtune/analyzer/bin/libATLBistroController_L2L.soFailed to load library /opt/intel/vtune/analyzer/bin/libSVPreferencePagesEC.soFailed to load library /opt/intel/vtune/analyzer/bin/libSamplingConsumerEcClient.soFailed to load library /opt/intel/vtune/analyzer/bin/libvtremoteconnector.soFailed to load library /opt/intel/vtune/analyzer/bin/libVTFormulaEngine.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGExeCtrlTLBps.soFailed to load library /opt/intel/vtune/analyzer/bin/libSamplingWizardEc.soFailed to load library /opt/intel/vtune/shared/bin/libZLibComponent.soFailed to load library /opt/intel/vtune/shared/bin/libvtlHandlers.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGC_L2L.soFailed to load library /opt/intel/vtune/shared/bin/libComInfops.soFailed to load library /opt/intel/vtune/analyzer/bin/libCGPackNGo.soFailed to load library /opt/intel/vtune/analyzer/bin/libSamplingWizardLogic.soFailed to load library /opt/intel/vtune/analyzer/bin/libSOTAccess.soFailed to load library /opt/intel/vtune/shared/bin/libFileSearchAddIn.soThe VTune Performance Analyzer 9.1 for Linux* may work incorrectly.
Press to continue.
===============================================================================INSTALLATION NOTES
Intel VTune Performance Analyzer 9.1 for Linux* installation------------------------------------------------------------------------------- Note: You need to be a member of the "users" group in order to use the VTune Performance Analyzer.Note: To invoke the VTune Performance Analyzer, run "/opt/intel/vtune/bin/vtl" for command line and "/opt/intel/vtune/bin/vtlec" to start the VTune Performance Analyzer within Eclipse.
Note: To uninstall the VTune Performance Analyzer 9.1 for Linux* please run "/opt/intel/vtune/bin/uninstall_vtune.sh" file. Press .
I tried to restart ntd:
[root@tesla:/home/ian/archives/vtune_linux_9.1/data] /etc/init.d/ntd restart
10:49:14 29-03-10 /etc/init.d/ntd: restart
10:49:14 29-03-10 /etc/init.d/ntd: Unsupported distribution.
10:49:14 29-03-10 /etc/init.d/ntd: Terminate.
[root@tesla:~] /etc/init.d/vtune status
[root@tesla:~]
I appreciate any help.
M
Peter_W_Intel
I saw systen info
Ubuntu 9.04
Note that current VTune Performance Analyzerv9.1 U7 doesn't supporton kernel 2.6.32, evenif you have no problem to build vtune driver and load it.
Please don't usethe tool on Ubuntu 9.04 RCn - which kernel version is> 2.6.30. Ubuntu 9.04 initial release (kernel 2.6.28) should be ok.
Wait for next productUpdate to support higher Linux* kernel version.
Regards, Peter
miklos_klaar
Peter
Thanks for the response. This might be a dumb question but would the wrong kernel version result in these kind of installation problems?
Best,
M
uncc_mosaic
Hi all,
I am trying to install the Vtune analyzer on a network setup with RHEL 5.4 64 bit. We are using AFS where many users have individual accounts. During installation, I could see many Warning messages similar to the ones which are posted here previously.Although the installation was complete, I was unable to execute the application as it required the "ntd" service to be running. When I tried starting this service, it gave one more error message saying - "chown: `sag:sag': invalid user". I have attached a file which contains all these error messages. I had a doubt regarding the installation -
How do I specify a network group name during installation? There is a network group called 'test' in our setup .When I gave this name, the setup went ahead with creating a new group 'test' on the local machine which was used for installation.
Any help is highly appreciated.
Sumanth
Peter_W_Intel
Quoting uncc_mosaic
Hi all,
Sumanth
I have comments -
1. If you specified "test" as "VTune analyzer group", your log-on user should be in "test" group
2. If you installed the product under network mounted driver from the server,Ithink thatlog-on user has to have permission to write data under that directory of NFS or AFS (from client side, changing global data and user directoryto local drive, change them via VTUNE_GLOBAL_DIR and VTUNE_USER_DIR environment variables..)
3. If you have problem on NTD service, you can use vtserver (instead of vtl and vtlec) - which doesn't require NTD service, usually it is a recommend working model (install the product on the server, and use the product from the client)
Hope it helps.
Regards, Peter
