Analyzers
5284 Discussions
Question on loads, stores and LLC miss count in Memory Access
Taehun_Kim
Hi, all.
I have been trying to profile memory access of an application using VTune.
And I have the following questions about loads, stores and LLC miss count.
1. Does load and store count represents loads/stores that occurred in LLC only? or does it counts every single load and store in L1, L2 and LLC?
2. I think LLC miss count should be the same with the DRAM access count, but what I got is DRAM access count is larger than LLC miss count. What would make this situation?
I attached the images for each question.
Thanks for answering in advance.
