Analyzers
Re: Hi Kirill,
afelt
I also am having this issue with VTune 2020 Update 3, that it is not recognizing my i7-8700t. Can you please explain how you updated sep and where you obtained the new version? Anything you can recommend to replicate your fix would be helpful. Thank you in advance.
Kirill_U_Intel
Hi.
Could you provide 'VTUNE_INSTALL_DIR/bin64/sep.exe -version' output?
Thanks, Kirill
afelt
Output from my 2020 Update 3 VTune:
Sampling Enabled Product Version: 5.21  (public)
PAX Driver Version: 1.0
Platform type: 122
CPU name: Intel(R) microarchitecture code named Coffeelake
PMU: skylake
Driver configs: Non-maskable Interrupt, REGISTER CHECK ON
Copyright (C) 2007-2020 Intel Corporation. All rights reserved.
afelt
While VTune installer complained, it seems to run just fine and perhaps I can safely ignore its message that it didn't recognize the CPU on install. It still says it can't recognize the GPU (integrated on the i7, not a discrete unit) but that's not a bother right this second.
JananiC_Intel
Your sep tool output is fine. In your last post you have mentioned that your cpu analysis is also working fine. So do you have any other update?Is your issue resolved?
Janani Chandran
JananiC_Intel
Glad to know that your cpu analysis is working. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Janani Chandran
