Analyzers
5293 Discussions
Resolving kernel symbols with Xeon Phi and MPSS 3.1.2
Tim_C_
I'm trying to understand why an application is spending lots of time in [vmlinux], but I can't get VTune to resolve the MIC's kernel. I have found some suggestions (http://software.intel.com/en-us/forums/topic/387212) to tell amplxe-cl to search /lib/firmware/mic to resolve kernel symbols, but this directory doesn't exist anymore. (I imagine it did with earlier versions of the MIC tools.)
I'm currently running amplxe-cl like so:
amplxe-cl -collect knc-hotspots -search-dir all:rp=/usr/share/mpss/firmware -- ssh mic0 naughtyprogram
However, the search path I've given doesn't help amplxe-cl resolve symbols in vmlinux, since
amplxe-cl -report hotspots -filter module=vmlinux -r tmp
only yields:
[vmlinux]  vmlinux         40.703
I'm running MPSS 3.1.2, which seems to have moved a lot of things around. How can I help vtune resolve vmlinux symbols?
robert-reed
Valued Contributor II
Sorry.  I've been meaning to write something about the changes for MPSS 3, and I just haven't been able to find the time, so I'll make a little time right now.  Yes, the location for kernel symbols has changed with MPSS 3, and a little preparatory work may be needed.  The new path you should become familiar with for MPSS 3 is /opt/mpss/3.1.2/sysroots/k1om-mpss-linux/ (substitute your MPSS version for the 3.1.2 string).  In that directory you should find a "boot" directory that will have a vmlinux image (mine is called vmlinux-2.6.38.8+mpss3.1.2, in keeping with being on MPSS 3.1.2).  You may need to add a symlink, vmlinux, pointing at that image:
$ ll
total 97280
-rw-r--r-- 1 root  2761952 Dec 18 19:17 bzImage-2.6.38.8+mpss3.1.2
lrwxrwxrwx 1 root       26 Jan 14 11:10 vmlinux -> vmlinux-2.6.38.8+mpss3.1.2
-rw-r--r-- 1 root 96739561 Dec 18 19:17 vmlinux-2.6.38.8+mpss3.1.2
VTune Amplifier looks for vmlinux.  If you add this path to the list within VTune Amplifier, it should be able to resolve MPSS 3 kernel symbols.  While you're there, you might also want to add /opt/mpss/3.1.2/sysroots/k1om-mpss-linux/lib64 to your list of  binary symbol paths, to resolve libc and other such references.
I still want to write this up for general availability, but hopefully these details will be adequate for you to move on from where you're stuck.
robert-reed
$ ll
total 97280
Tim_C_
Thanks! I've just created the symlink and pointed vtune in its direction and I'm in business now.
