Analyzers
5342 Discussions
Sampling driver installation error
dark-dante
I am using an AWS EC2 instance (r6in.2xlarge) which uses the Intel Xeon 8375C (Ice Lake) with an Ubuntu 22.04 image. I am followed all instructions to ensure I have the system requirements for the intel oneapi base kit, which was downloaded successully. However to use some tools such as the microarchitecture performance insights, I need the sampling drivers. However, I get the following problem:
ubuntu@ip-172-31-44-3:/opt/intel/oneapi/vtune/2023.0.0/sepdk/src$ sudo ./build-driver -ni
C compiler version: 11.3.0
Make version: 4.3
Kernel version: 5.15.0-1028-aws
Cleaning workspaces ...
Done
Building socperf driver ...
Skipping BTF generation for /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socperf/src/socperf3.ko due to unavailability of vmlinux
Done
Building sep driver ...
/opt/intel/oneapi/vtune/2023.0.0/sepdk/src/sys64.o: warning: objtool: SYS_Get_GDT_Base()+0x3: 'naked' return found in RETHUNK build
/opt/intel/oneapi/vtune/2023.0.0/sepdk/src/sys64.o: warning: objtool: SYS_IO_Delay()+0x0: 'naked' return found in RETHUNK build
/opt/intel/oneapi/vtune/2023.0.0/sepdk/src/sys64.o: warning: objtool: SYS_Get_GDT_Base()+0x3: missing int3 after ret
/opt/intel/oneapi/vtune/2023.0.0/sepdk/src/sys64.o: warning: objtool: SYS_IO_Delay()+0x0: missing int3 after ret
Skipping BTF generation for /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/sep5.ko due to unavailability of vmlinux
Done
Building pax driver ...
Skipping BTF generation for /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/pax/pax.ko due to unavailability of vmlinux
Done
Building vtsspp driver ...
make[1]: Entering directory '/opt/intel/oneapi/vtune/2023.0.0/sepdk/src/vtsspp'
Skipping BTF generation for /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/vtsspp/vtsspp.ko due to unavailability of vmlinux
make[1]: Leaving directory '/opt/intel/oneapi/vtune/2023.0.0/sepdk/src/vtsspp'
Done
Building socwatch driver ...
Building drivers for Linux target
-n switch is deprecated. Now it does not have any effect.
/lib/modules/5.15.0-1028-aws/build will be used as the kernel build directory
Removing previously built driver and scripts from /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/drivers
mkdir: cannot create directory ‘/opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/drivers’: File exists
-c /bin/gcc -l -k /lib/modules/5.15.0-1028-aws/build will be used to build the SoCWatch driver
************ Building socwatch2_15.ko driver ************
Using C compiler = /bin/gcc
Using kernel build dir = /lib/modules/5.15.0-1028-aws/build
No module symvers file found
Using common inc dir = /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/../common/include
"/lib/modules/5.15.0-1028-aws/build/include/linux/cpufreq.h" exists!
Using file name sw_driver
Make args = KERNEL_SRC_DIR=/lib/modules/5.15.0-1028-aws/build CPUFREQ_FIX_BACKPORTED=1 DO_DEBUG_BUILD=0 DO_PROFILING=0 COMMON_INC_DIR=/opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/../common/include MODULE_SYMVERS_FILE= FILE_NAME=sw_driver
make[1]: Entering directory '/opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver'
make -C /lib/modules/5.15.0-1028-aws/build M=/opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver clean
make[2]: Entering directory '/usr/src/linux-headers-5.15.0-1028-aws'
  CLEAN   /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/Module.symvers
make[2]: Leaving directory '/usr/src/linux-headers-5.15.0-1028-aws'
make[1]: Leaving directory '/opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver'
DO_SOCPERF=0
DO_DRIVER_PROFILING=0
INCDIR_1=/opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/../common/include
make -C /lib/modules/5.15.0-1028-aws/build M=/opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver modules PWD=/opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver
  CC [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_driver.o
  CC [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_hardware_io.o
  CC [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_output_buffer.o
  CC [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_tracepoint_handlers.o
  CC [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_collector.o
  CC [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_mem.o
  CC [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_internal.o
  CC [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_file_ops.o
  CC [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_ops_provider.o
  CC [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_trace_notifier_provider.o
  CC [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_reader.o
  CC [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_telem.o
  CC [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_pmt.o
  CC [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_counter_list.o
  CC [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_pci.o
  LD [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.o
  MODPOST /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/Module.symvers
  CC [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.mod.o
  LD [M]  /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.ko
  BTF [M] /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.ko
Skipping BTF generation for /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.ko due to unavailability of vmlinux
************ Built drivers are copied to /opt/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/drivers directory ************
Done
mv: cannot stat 'socwatch/drivers/socwatch2_15-x32_64-5.ko': No such file or directory
make: *** [Makefile:224: default] Error 1
Failed to build the drivers
I have followed this thread: https://community.intel.com/t5/Analyzers/Unable-to-build-sepdk-driver/m-p/1369494#M21980 but it hasn't helped my case. Is there a reason why this is happening ? Can anyone point me to a fix ? Thanks.
dark-dante
An update to the post above:
When I ran ./insmod-sep -q, I get the following:
ubuntu@ip-172-31-86-17:/opt/intel/oneapi/vtune/2023.0.0/sepdk/src$ ./insmod-sep -q
pax driver is loaded and owned by group "vtune" with file permissions "660".
socperf3 driver is not correctly loaded.
sep5 driver is not correctly loaded.
socwatch driver is loaded and owned by group "vtune" with file permissions "660".
 I tried to follow Vladimir_T_Intel's advice from https://community.intel.com/t5/Analyzers/Sampling-drivers-not-loaded-correctly/m-p/1184259 where I fully unloaded the driver (./rmmod-sep -s) and loaded it again (./insmod-sep). After that, this is the output:
ubuntu@ip-172-31-86-17:/opt/intel/oneapi/vtune/2023.0.0/sepdk/src$ ./rmmod-sep -s
NOTE:  super-user or "root" privileges are required in order to continue.
Please enter "root" Password:
Removing sep5 driver from the kernel ... done.
The sep5 driver has been successfully unloaded.
Removing vtsspp driver from the kernel ... done.
The vtsspp driver has been successfully unloaded.
Removing socwatch2_15 driver from the kernel ... done.
The socwatch2_15 driver has been successfully unloaded.
Removing socperf3 driver from the kernel ... done.
The socperf3 driver has been successfully unloaded.
Attempting to stop PAX service ...
Removing pax driver from the kernel ... done.
The pax driver has been successfully unloaded.
PAX service has been stopped.
ubuntu@ip-172-31-86-17:/opt/intel/oneapi/vtune/2023.0.0/sepdk/src$ sudo ./build-driver -ni
Make version: 4.3
Done
Done
Done
Done
Done
DO_SOCPERF=0
Done
pax driver is not loaded.
socperf3 driver is not loaded.
sep5 driver is not loaded.
socwatch driver is not loaded.
vtsspp driver is not loaded.
Now, no driver is loaded and it is worse than before.
RemyaP_Intel
Thank you for posting in Intel communities.
We are unable to reproduce your issue. We followed the same steps for loading the drivers in Ice Lake machine(Ubuntu 22.04). All the drivers were loaded successfully without any error messages.
sdp@001b21ea7043:~/intel/oneapi/vtune/2023.0.0/sepdk/src$ sudo su
root@001b21ea7043:/home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src# ./insmod-sep -q
root@001b21ea7043:/home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src# ./build-driver -ni
Make version: 4.3
Kernel version: 5.15.0-57-generic
Done
Skipping BTF generation for /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socperf/src/socperf3.ko due to unavailability of vmlinux
Done
/home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/sys64.o: warning: objtool: SYS_Get_GDT_Base()+0x3: 'naked' return found in RETHUNK build
/home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/sys64.o: warning: objtool: SYS_IO_Delay()+0x0: 'naked' return found in RETHUNK build
/home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/sys64.o: warning: objtool: SYS_Get_GDT_Base()+0x3: missing int3 after ret
/home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/sys64.o: warning: objtool: SYS_IO_Delay()+0x0: missing int3 after ret
Skipping BTF generation for /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/sep5.ko due to unavailability of vmlinux
Done
Skipping BTF generation for /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/pax/pax.ko due to unavailability of vmlinux
Done
make[1]: Entering directory '/home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/vtsspp'
Skipping BTF generation for /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/vtsspp/vtsspp.ko due to unavailability of vmlinux
make[1]: Leaving directory '/home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/vtsspp'
Done
/lib/modules/5.15.0-57-generic/build will be used as the kernel build directory
Removing previously built driver and scripts from /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/drivers
mkdir: cannot create directory ‘/home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/drivers’: File exists
-c /bin/gcc -l -k /lib/modules/5.15.0-57-generic/build will be used to build the SoCWatch driver
Using kernel build dir = /lib/modules/5.15.0-57-generic/build
Using common inc dir = /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/../common/include
"/lib/modules/5.15.0-57-generic/build/include/linux/cpufreq.h" exists!
Make args = KERNEL_SRC_DIR=/lib/modules/5.15.0-57-generic/build CPUFREQ_FIX_BACKPORTED=1 DO_DEBUG_BUILD=0 DO_PROFILING=0 COMMON_INC_DIR=/home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/../common/include MODULE_SYMVERS_FILE= FILE_NAME=sw_driver
make[1]: Entering directory '/home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver'
make -C /lib/modules/5.15.0-57-generic/build M=/home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver clean
make[2]: Entering directory '/usr/src/linux-headers-5.15.0-57-generic'
  CLEAN   /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/Module.symvers
make[2]: Leaving directory '/usr/src/linux-headers-5.15.0-57-generic'
make[1]: Leaving directory '/home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver'
DO_SOCPERF=0
INCDIR_1=/home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/../common/include
make -C /lib/modules/5.15.0-57-generic/build M=/home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver modules PWD=/home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver
  CC [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_driver.o
  CC [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_hardware_io.o
  CC [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_output_buffer.o
  CC [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_tracepoint_handlers.o
  CC [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_collector.o
  CC [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_mem.o
  CC [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_internal.o
  CC [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_file_ops.o
  CC [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_ops_provider.o
  CC [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_trace_notifier_provider.o
  CC [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_reader.o
  CC [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_telem.o
  CC [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_pmt.o
  CC [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_counter_list.o
  CC [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/./src/sw_pci.o
  LD [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.o
  MODPOST /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/Module.symvers
  CC [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.mod.o
  LD [M]  /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.ko
  BTF [M] /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.ko
Skipping BTF generation for /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.ko due to unavailability of vmlinux
************ Built drivers are copied to /home/sdp/intel/oneapi/vtune/2023.0.0/sepdk/src/socwatch/drivers directory ************
Done
Done building the drivers
PYTHON is set to python3
Detecting Secure Boot status...
Secure Boot is disabled
---------------------    Loading PAX driver    ---------------------
Checking for PMU arbitration service (PAX) ... not detected.
Attempting to start PAX service ...
Executing: insmod ./pax/pax-x32_64-5.15.0-57-genericsmp.ko
Setting group ownership of devices to group "vtune" ... done.
Setting file permissions on devices to "660" ... done.
The pax driver has been successfully loaded.
---------------------  Loading SOCPERF driver  ---------------------
Checking for socperf driver ... not detected.
Attempting to start socperf service ...
Executing: insmod ./socperf/src/socperf3-x32_64-5.15.0-57-genericsmp.ko
The socperf3 driver has been successfully loaded.
---------------------    Loading SEP driver    ---------------------
Executing: insmod ./sep5-x32_64-5.15.0-57-genericsmp.ko sym_lookup_func_addr="ffffffff927984e0"
The sep5 driver has been successfully loaded.
---------------------  Loading VTSSPP driver  ---------------------
Checking for vtsspp driver ... not detected.
Executing: insmod ./vtsspp/vtsspp-x32_64-5.15.0-57-genericsmp.ko gid=1003 mode=0660 ksyms="ffffffff927984e0"
The vtsspp driver has been successfully loaded.
--------------------- Loading SOCWATCH driver ---------------------
Checking for socwatch driver ... not detected.
Executing: insmod ./socwatch/drivers/socwatch2_15-x32_64-5.15.0-57-genericsmp.ko
Setting group ownership of device file to group "vtune" ... done.
Setting file permissions of device file to "660" ... done.
The socwatch driver has been successfully loaded.
NOTE:
The driver is accessible only to users under the group vtune.
Please add the users to the group 'vtune' to use the tool.
To change driver access group, reinstall the driver using -g <desired_group> option.
NOTE:
Please add the users to the group vtune to use the tool.
To change driver access group, reload the driver using -g <desired_group> option.
socperf3 driver is loaded and owned by group "vtune" with file permissions "660".
sep5 driver is loaded and owned by group "vtune" with file permissions "660".
vtsspp driver is loaded and owned by group "vtune" with file permissions "660".
We assume, the reason could be because of using the AWS EC2 instance. Could you please try loading the drivers without using EC2 instance and let us know the results
Remya Premdas
dark-dante
Unfortunately, I need to use the EC2 Instance to access the a system with an Intel Xeon. I have tried this with both the r5.metal and r6in.2xlarge instances. Both fail to install the drivers properly.
RemyaP_Intel
Please follow the steps given in the below link and see if that resolves your issue.
https://www.intel.com/content/www/us/en/develop/documentation/vtune-cookbook/top/configuration-recipes/profiling-applications-in-aws-ec2-instances.html
Remya Premdas
RemyaP_Intel
We haven't received any response from your end. Is your issue resolved?
Remya Premdas
RemyaP_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Remya Premdas
CFR
New Contributor II
I ended up here looking for a explanation of the "warning: objtool" and "skipping BTF" messages when building the drivers from the source in OneAPI 2024.0.  My drivers seem to have built correctly but I'd like to understand what those two notifications mean and whether they have any implications I should know of.
(we built the drivers but have not yet installed them)
yuzhang3_intel
Skipping BTF generation for sepint5.ko due to unavailability of vmlinux
  • Caused by vmlinux file missing in the kernel header/source on the system.
  • This is the environment issue
Warning:objtool: SYS_Get_GDT_Base()+0x3: ‘naked’ return found in RETHUNK build
  • Caused by improper use of assembly code in the driver since some changes from kernel.
They both are warnings, so there is no impact to the driver functionality.
CFR
New Contributor II
