Analyzers
5340 Discussions
Segmentation Fault in FGA
zeronsix
Hi!
I'm using the fgt_run.sh script to generate profiling traces of my oneTBB application for Flow Graph Analyzer. The script successfully generates *.graphml and *.traceml files.
However, I get segmentation fault when I try to open my_application.graphml with FGA.
/run_fga.sh: line 24: 4167772 Segmentation fault      (core dumped) ${DIR}/fga &> /dev/null
I use FGA version 2020 1.1.17998 and oneTBB 2021.2.0.
Please find the archive with the collected traces attached.
JananiC_Intel
Thanks for posting in Intel forums.
We are checking on this. Meanwhile could you share a sample reproducer and your OS details?
Janani Chandran
zeronsix
I run the application inside nvidia/cuda:11.3.1-cudnn8-devel-ubuntu20.04 Docker container, meanwhile FGT is installed inside the container from intel-oneapi-advisor package from https://apt.repos.intel.com/oneapi repository. oneTBB is built from the source code as a CMake target along with the project itself.
Unfortunately, it is hard to share a sample reproducer without unveiling the key proprietary technologies and approval in our legal department could take ages.
zeronsix
I've managed to find the source of the problem. The flow graph was wrapped with a composite node. The output node of the graph is a tbb::flow::function_node<Result, tbb::flow::continue_msg, tbb::flow::queueing>, so the composite node had tbb::flow::composite_node<std::tuple<Input>, std::tuple<tbb::flow::continue_msg>> type. When I moved the output node outside of the composite node, FGA stopped crashing.
JananiC_Intel
Glad to know that your issue is resolved. Thanks for sharing the solution with us. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Janani Chandran
