Analyzers
5285 Discussions
Specify the installation location in vtune install iwith CLI
Hannah_zhen
Hi community:
I am installing the latest vtune in Centos7 server with offline installer.
However, I was wondering if it is possible to modify the path for installation (marked with red)
Since there is not enough disk space, I want to change the installation location to my directory which is sufficient in /dev/sda/
Jennifer_D_Intel
You can select "Accept and customize" to change the installation directory:
Tab to and select "Next"
Then you will get the option to change the directory:
Jennifer_D_Intel
