Analyzers
5341 Discussions
System hangs Post Execution
Natesh_B_Intel
System hangs after executing... The only alternative is to restart. Pls look in to this and guide us.
I have attached the screen shots for your ref.....
Cheers,
Praveen
Andrey_Pavlenko
I'd suggest you adding more details regarding you hardware, software and VTune package ID you use. I can increase a chance to get an answer :)
Anyway, the problem looks atypical and not easy to investigate, so the most effective way for you to submit a request at https://premier.intel.com/tostart an official investigation process.
/Andy.
David_A_Intel1
Based on the screen shot, I would suggest using either the Counter Monitor Wizard, the Sampling Wizard or the Call Graph Wizard and one of the example applications included in the VTune analyzer installation (see C:Program FilesIntelVTuneExamples, by default). This will help narrow down which component may be failing. It also may resolve the issue completely! That is, running multiple collectors at the same time tends to be problematic, at best.
