Analyzers
5339 Discussions
Unable to run First use Wizard(Sampling)
Anonymous74
Dear All,
I am new to VTune Performance tools, I have installed VTune 8.0 for Linux. When going through the "Getting started" document, I got the following error"CCTEBSCollector::SERA_GetEventsMgr - Failed"when trying to use, "First use Wizard" under Tuning Wizard. Kindly let me know, if anyone have faced this error before. Thanks in advance.
Warm Regards,
Sandeep.
Intel_C_Intel
Hi Sandeep:
Welcome to the forum. I haven't seen that error message before, but it could be something having to do with the sampling driver. There are updated drivers at: http://www.intel.com/cd/software/products/asmo-na/eng/229869.htm. If you don't find a pre-built driver for your kernel, you can also download the VTune analyzer Driver Kit by clicking the VTune Performance Analyzer Driver Kit link just above the table of pre-built drivers. Also, check the Release Notes for the list of tested environments. If none of this works, you can submit a technical support issue at https://premier.intel.com and the tech support team will respond to the question. Hope this helps!
Anonymous74
Hi Jack,
Sorry for the late reply, I was not in office. My license has expired, I shall check the same on Windows and shall let you know about the outcome. Thanks.
Warm Regards,
Sandeep.
