Analyzers
5338 Discussions
Unsupported Level Zero Graph Extensions version detected
Martin_HZK
When I am trying to profile the ipex-llm NPU examples, I receive the error message in the Collection Log, indicating the "Unsupported Level Zero Graph Extensions version detected: 1.7. The Graph Extensions will not be instrumented." The detailed Collection Log messages is listed in the Collection Log.png.
The application is llm-npu-cli.exe built according to the document for ipex-llm NPU CPP_Examples and the model is the converted  Qwen/Qwen2-1.5B-Instruct, using the convert.py.
Is it the problem related to the Vtune profiler version or what?
NPU driver version: 32.0.100.3104
OS version: Windows 11 Pro for Workstations 23H2
oneAPI version: 2025.0
Martin_HZK
@yuzhang3_intel Dear yuzhang, could you help with this question post?
yuzhang3_intel
It looks like VTune doesn't support the current level zero version. Can you roll npu driver back to older version and try?
Martin_HZK
How is the NPU version related to the VTune and level zero version?
In addition, the NPU version is specified by the ipex-llm, otherwise we may not be able to convert the llm weights to the quantized version. (I think its a bit chaotic tbh
yuzhang3_intel
Can you share the VTune data?
Martin_HZK
Sure, the VTune data is listed below.
yuzhang3_intel
Just confirmed with engineering team, this is one known issue, will be fixed in future release.
Martin_HZK
Sure, many thanks for your clarification. So currently, what kinds of NPU APIs are fully supported for NPU profiling via VTune?
yuzhang3_intel
VTune NPU profiling has a dependency on level zero graph extensions, VTune 2025.0.1 has support till GE 1.10.
This is one known issue that has been fixed in future releases.
