Analyzers
VS2019 integration
Moussi__Yasmine
I dowloaded the trial version of Intel Vtune Amplifier 2019 and followed all the steps in the link below to integrate it to VS2019 :
https://software.intel.com/en-us/vtune-amplifier-help-microsoft-visual-studio-integration
Unfortunately, I can't get Vtune Amplifier in the tools menu. Doesn't the trial version offer this integration or is it not compatible with VS2019?
Could you please help us with this problem ?
Nika_D_Intel
Hello Moussi,
Could you please specify which update of Intel VTune Amplifier 2019 is used?
VS2019 is supported since Update 4.
Nika D
Moussi__Yasmine
I am using Update 4.
Best regards.
Nika_D_Intel
There is a amplxe-vs-integration.vsix file on the VTune root directory. You can install VS extension by double click on it or run command line
<the same directory as devenv.exe>VSIXInstaller.exe <path to amplxe-vs-integration.vsix>.
Nika.
