Analyzers
5259 Discussions
VS6.0 Project/Settings needed for VTune?
danijeldomazet
What options do I have to select in my Microsoft VS6.0 Project/Settings (compiler and linker settings)in order to connect with VTune the best way I can? Debug version of my project works fine with VTune, but it is not optimized. Release version, which is in fact real-life version, misses debug information and VTune does not see function names! I have made 3th configuration (Profile) which has same setting as Release except Debug info which is now set to "Program Database". Is this ok or I need to select some other options since I still cannot see all function names in VTune?
Thanx
danijeldomazet
I did some manual reading so settings are fine now... sorry...
