Analyzers
5269 Discussions
VTSS driver failing to start with exit code -6
R-Goc
I tried using vtune but am unable to detect the hardware. After some follow up looking I'm getting the following issue:
C:\Windows\System32>amplxe-sepreg.exe -i
Warning, socperf3 driver is already installed and will be re-used... skipping
Installing and starting sepdrv5... OK
Installing and starting sepdal... OK
Installing and starting vtss... FAILED
Reason: Failed to start vtss service; error code: -6
According to a previous forum post this could be related to the windows version.
I am currently on the beta channel build:
Edition Windows 11 Home
Version 23H2
Installed on ‎2/‎17/‎2024
OS build 22635.3646
Experience Windows Feature Experience Pack 1000.22700.1013.0
Vtune version:
C:\Windows\System32>vtune --version
Intel(R) VTune(TM) Profiler 2024.1.0 (build 627630) Command Line Tool Copyright (C) 2009 Intel Corporation. All rights reserved.
R-Goc
Attaching vtune self checker output log:
yuzhang3_intel
Is there any output from 'sep.exe -version' (run a console as administrator)?
R-Goc
No there is no output.
yuzhang3_intel
Thanks for reporting the issue. This is one known issue observed on the latest Windows 11 builds. The issue will be fixed in future releases.
