Analyzers
5281 Discussions
[VTUNE] sep5.service failed: 236/SMACK_PROCESS_LABEL
Bram_S_
After installing intel-oneapi-vtune (2023.1.0-44286) on Ubuntu 23.04:
$ sudo systemctl status sep5
× sep5.service - systemd script to load sep5 driver at boot time
     Loaded: loaded (/lib/systemd/system/sep5.service; enabled; preset: enabled)
     Active: failed (Result: exit-code) since Thu 2023-04-27 12:50:19 PDT; 6min ago
    Process: 261391 ExecStart=/usr/local/sbin/sep5-load.sh start (code=exited, status=236/SMACK_PROCESS_LABEL)
   Main PID: 261391 (code=exited, status=236/SMACK_PROCESS_LABEL)
        CPU: 62ms
Apr 27 12:50:19 deca systemd[1]: Starting sep5.service - systemd script to load sep5 driver at boot time...
Apr 27 12:50:19 deca sep5-load.sh[261391]: Loading the sep5 driver:
Apr 27 12:50:19 deca groupmod[261445]: group changed in /etc/group (group vtune/1002)
Apr 27 12:50:19 deca sep5-load.sh[261392]: The sep5 driver is already loaded!  Use ./rmmod-sep to unload it.
Apr 27 12:50:19 deca systemd[1]: sep5.service: Main process exited, code=exited, status=236/SMACK_PROCESS_LABEL
Apr 27 12:50:19 deca systemd[1]: sep5.service: Failed with result 'exit-code'.
Apr 27 12:50:19 deca systemd[1]: Failed to start sep5.service - systemd script to load sep5 driver at boot time.
OS: Ubuntu 23.04
CPU: i12600k
IonutNechita
Hi @yuzhang3_intel ,
I installed steps, 2.1.2 and 2.1.3 and i notice similar output:
 /opt/intel/oneapi/vtune/latest/bin64/vtune-self-checker.sh
Intel(R) VTune(TM) Profiler Self Check Utility
Copyright (C) 2009 Intel Corporation. All rights reserved.
Build Number: 627177
HW event-based analysis (counting mode) (Intel driver)
Example of analysis types: Performance Snapshot
    Collection: Ok
    Finalization: Ok...
    Report: Ok
Instrumentation based analysis check
Example of analysis types: Hotspots and Threading with user-mode sampling
    Collection: Ok
    Finalization: Ok...
    Report: Ok
HW event-based analysis check (Intel driver)
Example of analysis types: Hotspots with HW event-based sampling, HPC Performance Characterization, etc.
    Collection: Ok
vtune: Warning: To enable hardware event-based sampling, VTune Profiler has disabled the NMI watchdog timer. The watchdog timer will be re-enabled after collection completes.
    Finalization: Ok...
vtune: Warning: Cannot locate debugging information for the Linux kernel. Source-level analysis will not be possible. Function-level analysis will be limited to kernel symbol tables. See the Enabling Linux Kernel Analysis topic in the product online help for instructions.
    Report: Ok
Example of analysis types: Microarchitecture Exploration
    Collection: Ok
    Finalization: Ok...
vtune: Warning: The result contains a lot of raw data. Finalization may take a long time to complete.
    Report: Ok
HW event-based analysis with uncore events (Intel driver)
Example of analysis types: Memory Access
    Collection: Ok
    Finalization: Ok...
    Report: Ok
HW event-based analysis with stacks (Intel driver)
Example of analysis types: Hotspots with HW event-based sampling and call stacks
    Collection: Ok
    Finalization: Ok...
    Report: Ok
HW event-based analysis with context switches (Intel driver)
Example of analysis types: Threading with HW event-based sampling
    Collection: Ok
    Finalization: Ok...
    Report: Ok
Checking DPC++ application as prerequisite for GPU analyses: Ok
GPU HW event-based analysis with runtime tracing
Example of analysis types: GPU Compute/Media Hotspots (characterization mode)
    Collection: Ok
    Finalization: Ok...
    Report: Ok
GPU software event-based analysis with runtime tracing
Example of analysis types: GPU Compute/Media Hotspots (source analysis mode)
    Collection: Fail
vtune: Error: [Instrumentation Engine]: GTPin:  IGC-GTPin interface version 4090511487 is not supported
vtune: Warning: [Instrumentation Engine]: GTPin:  GTPin didn't find any kernels... Exiting without doing anything.
The check observed a product failure on your system.
Review errors in the output above to fix a problem or contact Intel technical support.
The system is ready for the following analyses:
* Performance Snapshot
* Hotspots and Threading with user-mode sampling
* Hotspots with HW event-based sampling, HPC Performance Characterization, etc.
* Microarchitecture Exploration
* Memory Access
* Hotspots with HW event-based sampling and call stacks
* Threading with HW event-based sampling
* GPU HW event-based analysis with runtime tracing
The following analyses have failed on the system:
* GPU Compute/Media Hotspots (source analysis mode)
IonutNechita
I updated this packages:
Get:1 https://repositories.intel.com/gpu/ubuntu jammy/client amd64 libdrm-dev amd64 2.4.112.4+2056~u22.04 [279 kB]
Get:2 https://repositories.intel.com/gpu/ubuntu jammy/client amd64 libdrm-intel1 amd64 2.4.112.4+2056~u22.04 [72,8 kB]
Get:3 https://repositories.intel.com/gpu/ubuntu jammy/client amd64 libdrm-radeon1 amd64 2.4.112.4+2056~u22.04 [31,0 kB]
Get:4 https://repositories.intel.com/gpu/ubuntu jammy/client amd64 libdrm-nouveau2 amd64 2.4.112.4+2056~u22.04 [27,4 kB]
Get:5 https://repositories.intel.com/gpu/ubuntu jammy/client amd64 libdrm-amdgpu1 amd64 2.4.112.4+2056~u22.04 [29,5 kB]
Get:6 https://repositories.intel.com/gpu/ubuntu jammy/client amd64 libdrm2 amd64 2.4.112.4+2056~u22.04 [45,1 kB]
Get:7 https://repositories.intel.com/gpu/ubuntu jammy/client amd64 libdrm-common all 2.4.112.4+2056~u22.04 [4.604 B]
Get:8 https://repositories.intel.com/gpu/ubuntu jammy/client amd64 intel-metrics-discovery amd64 1.12.169-775~22.04 [3.917 kB]
Get:9 https://repositories.intel.com/gpu/ubuntu jammy/client amd64 libigc1 amd64 1.0.15136.24-775~22.04 [22,1 MB]
Get:10 https://repositories.intel.com/gpu/ubuntu jammy/client amd64 libigdfcl1 amd64 1.0.15136.24-775~22.04 [34,4 MB]
Fetched 60,9 MB in 33s (1.863 kB/s)
And now i have this:
    Collection: Ok
    Finalization: Ok...
    Report: Ok
    Collection: Ok
    Finalization: Ok...
    Report: Ok
    Collection: Ok
    Finalization: Ok...
    Report: Ok
    Collection: Ok
    Finalization: Ok...
    Report: Ok
    Collection: Ok
    Finalization: Ok...
    Report: Ok
    Collection: Ok
    Finalization: Ok...
    Report: Ok
    Collection: Ok
    Finalization: Ok...
    Report: Ok
    Collection: Ok
    Finalization: Ok...
    Report: Ok
    Collection: Ok
    Finalization: Ok...
    Report: Ok
The system is ready to be used for performance analysis with Intel VTune Profiler.
Review warnings in the output above to find product limitations, if any.
* Memory Access
* GPU software event-based analysis with runtime tracing
Log location: /tmp/vtune-tmp-root/self-checker-2024.03.07_17.53.45/log.txt
yuzhang3_intel
From the self-check result, the VTune environment is ready now, you can do profiling on CPU/GPU.
yuzhang3_intel
BTW, can you share the instructions you update packages? thanks.
IonutNechita
Ok. Understood.
But for sep5.service this service remain failed.
In this case i restarted target and this issue is gone.
Maybe this issue appear for first installation without reboot machine.
