Analyzers
5307 Discussions
VTune 2023.0.0 crashed everytime when using user-mode sampling
g199209
Crashed everytime when using user-mode sampling in hotspots analysis. Memory consumption analysis also crashed.
Local Machine: macOS
Target: Remote Linux (SSH)
The `vtune-worker --type=result` command crashed, when trying to loading `xxx.pytrace` file:
I have tried 2023.1.0, also crashed.
292653 [0x305f72000] ERROR cfgmgr <> - (outputBag != __null) && (inputBag != __null) && !m_ctx.is_null() 'gh2::error::FailedTo.Process.The.Parameter:'
vcs/cfgmgr2/src/rules.cpp(2020): gen_helpers2::error_code_t cfgmgr2::RuleProcessor::process(gen_helpers2::variant_bag_t *, const gen_helpers2::variant_bag_t *)
, at file: vcs/cfgmgr2/src/rules.cpp:2020
See attached files for detail.
1. Selected crash_info.txt
2. crashed process log
DiyaN_Intel
The Intel VTune GUI is not supported on M1/M2 CPUs, only on x86 CPUs.
A workaround is to run the VTune server (backend) and open a browser from the Mac to the system running the VTune server.
Port Forwarding in Servers:
If you have a web browser on your host machine, you can follow the below process.
Note: VPN must be disconnected while doing port forwarding in servers
Step 1: To connect to a remote server, we use "ssh user_name@<IP_address of that server>"
Since we need to port forward from our local host to the remote server, we use the below command.
ssh -L localhost:<port_number>:localhost:<port_number> <server_username@server_ipaddress>
Eg: ssh -L localhost:8080:localhost:8080 sdp@10.165.154.190
Step 2: Source the variables.
 source /opt/intel/oneapi/setvars.sh
Step 3: Let us try to open the GUI of Vtune
vtune-backend --web-port 8080 --allow-remote-access --enable-server-profiling
Step 4: After running the above command, you can see two links are generated. Copy any one of the GUI links (Note: do not press ctrl+C) and open it in any of your browsers.
Step 5: Click on “Advanced” and proceed and set the passphrase.
The passphrase should contain:
* A special character
* Any capital alphabet
* The length of the passphrase should be a minimum of 8 characters.
Vtune can now be accessed from a browser and you can do the respective analysis.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issues.
Thanks and Regards,
Diya
g199209
Performance Snapshot, hardware event-based sampling in hotspots analysis and microarchitecture exploration work well.
DiyaN_Intel
We are working on this issue internally and will get back to you with an update soon.
Thanks and regards,
Diya
DiyaN_Intel
Thanks and Regards,
Diya
DiyaN_Intel
Glad to know that your issue is resolved. Thanks for accepting our solution.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
Diya
