Analyzers
5315 Discussions
VTune 9.0 output Error: Invalid Path(4)
kalven
I'm evaluating VTune9.0 now. With Qucick Performance Analysis Wizard, I want to Collect Sampling data. I selected my exe file in Application To Launch, with default selection of "Collect Sampling data", I clicked Go.
The following were informations in output window:
Setting Samping Cpu mask to 0
The processor PMU configuration file: psc.xml
Collection for the following event(s) is being ferformed
clockticks
Error: Invalid path(4)
Can someone tell me what's wrong?
Vladimir_T_Intel
By default VTune saves project data on the path like that:
":Documents and SettingsApplication DataVTuneProjects"
Check if this path contains some localized symbols, e.g. in the
Also try the Sampling wizard instead QPA and see if it doesn't work better.
kalven
My default project path is C:Documents and Settings�4044Application DataVTune. There is no Projects directory, I created it myself. There isnot any localized symbols. Perhaps there is something wrong with QPA, but your document suggested using QPA for a fast see.
For Samplint wizard, I tried. I didnt know what's wrong. When I created new project, it default create a directory F:VTune, just behind VTune, there were some chinese words. As you said, the problem must be these localized chinese words. So I recreated a new directory vtune, it's OK.
Thanks all the same.
Vladimir_T_Intel
Ok. It looks like you faced with both problems: QPA and localized symbols in the path (the second case). So, the general advice would be to not use QPA (since it could be buggy on some platforms) and to make sure that there are no localized symbols in paths.
jluiselvira
Hello
At this moment Im experiencing the same problem with Vtune, using Sampling Wizard or QPA, I always get :
(Run 1) Invalid path (4)
The Project directory is:, and there are the projects on it.
C:Documents and SettingsJos LuisDatos de programaVTuneProjects
So, I would like to know what can I do ?
Thanks a lot
jluiselvira
Hello again
I thing that I know the problem, localized symbols in user name, just like , right ???, but how can you change the default path for projects ???
Thanks in advance
Vladimir_T_Intel
Yes, most likely it's because of this symbol. When creating new project just select other project location (e.g. C:my_tuning_projects) and VTune will keep this location for further reference.
jluiselvira
Thank you very much, I have changed the with e, and automatically created the new path"C:Documents and SettingsJose LuisDatos de programaVTuneProjects", so it is solved!!!
Vladimir_T_Intel
You are welcome! :)
Take care.
