I'm attempting to use VTune to analyze a project, and it always crashes before I get the results. It prompts me for the location of the uncompressed kernel, and I skip this. However, it crashes immediately after.
I have successfully run VTune on other sample code, it just doesn't work on my project. Any help debugging this would be greatly appreciated, I'm not sure where VTune keeps log files.
AJ
AJ
After further inspection, it may have to do with the project I am working on. If interested, you can check out the source with:
I'm attempting to use VTune to analyze the test file, src/test. I'm currently searching for the particular part of the source code that is causing the crash.
AJ
svn co http://svn.yetisim.org/svn/yetisim/trunk/yetisim
AJ
