Analyzers
5342 Discussions
VTune does not cache source files
softworkz
VTune Profiler 2021.1.1 Gold (Build 613804) Windows
Hotspots View
Whenever I navigate to the Source View (eg. gfrom the Bottom-Up view), a small message is shown at the bottom right, saying "Source file is saved in the result cache".
Now I change the code, recompile and do another run in VTune.
When I go to an earlier result (to compare), and navigate to the source file, it doesn't show a cached version - it shows the current version instead with the timings not matching the code lines anymore.
I assume, this is a bug?
softworkz
AthiraM_Intel
Please make sure that you enabled the "cache source files". To enable it follow the below step:
Go to Tools --> Options --> Source/Assembly.
If you are still facing the issue, please share the below details:
1. Details about the application you are using.
2. Reproducer code.
3. The changes you made in the code.
4. Finalization mode
softworkz
I have activated that option for caching source files.
1. and 2.: ffmpeg source code compiled with gcc on Windows under MSYS2
3. Any change to the code file as soon as I change the code file. Which means that it loads the source file from the original location instead of a cache location.
4. Full
softworkz
AthiraM_Intel
We are forwarding your case to Subject matter Experts.
Mark_L_Intel
Asked for engineering team support on your issue.
Mark_L_Intel
Engineering team reports that it reproduced the issue on the matrix application built with gcc on Linux. Possible solutions that would fix this issue are identified.
