Analyzers
5339 Discussions
VTune host name string was invalid
natron21
I've installed the VTune analyzer on a SLES11. I had to build a driver for the OS but this wasn't the problem in fact the whole installation made no problem at all.
I tried the example in the "Getting Started...@ tutorial and the following line:
./vtl activity -d 30 -c sampling -c callgraph -master sampling -app ./vtunedemo -moi ./vtunedemo run
Every case ends with the same error message:
<:DETERMINEREMOTESTATUS>Vtune host name string was invalid.
Where can I set the host name or how can I avoid this error.
Kind regards
Harry
Peter_W_Intel
Quoting - natron21
Kind regards
Harry
Hi Harry,
I did same vtl command on my side, there is no problem. It seems this is EBSrelevant from error message - so would you please check below?
1)Are you capable to do EBS only?
./vtl activity -d 30 -c sampling -app ./vtunedemo run
2) Ensure what data collectors can be used in your system
./vtl query -lc
3) Ensure sampling driver is in your system
lsmod | grep vtune
By the way, the user has to install the product in "root" user.
Best regards, Peter
natron21
Hi Harry,
./vtl query -lc
lsmod | grep vtune
Best regards, Peter
Hi Peter,
First of all, thanks for helping me.
I worked the list through.
1) ./vtl activity -d 30 -c sampling -app ./vtunedemo run
-> Same error as my command. <:DETERMINEREMOTESTATUS>Vtune host name string was invalid.
2) ./vtl query -lc
-> sampling and callgraph is availableon my system
3) lsmod | grep vtune
-> vtune_drv 237076 0
4) By the way, the user has to install the product in "root" user.
I installed the program as root user.
I'm also testing at the moment as root user. Is that a problem?
Maybe I should mention that my program is only a trial-version at the moment .
Hope you have some ideas left for me, I would really appreciate to work with vtune.
Best regards, Harry
Peter_W_Intel
Quoting - natron21
Hi Peter,
2) ./vtl query -lc
Best regards, Harry
Hi Harry,
Thanks for your reply. I don't think trial version to impact on the result. I even think thatyoucan work as a root user on VTune Analyzer. I doubt that VTune host name should not be the issue...
I reviewed the release notes of v9.1 U2 - SLES 11 still be not supported (I think it will be in next release). I understand that you built the driver successfully...but it hasn't been tested. So I suggest to use supported OS, like as
SuSE* Linux* Enterprise Server (SLES) 10.0 (through Service Pack 2) 2.6.16.60-0.21
I also suggest you to check if your processor is supported in release notes.
If need SLES 11 support urgently -pleaseaccess https://premier.intel.com to submit a ticket.
Regards, Peter
