Analyzers
5273 Discussions
VTune in Vista crashing applications
postaquestion
After installing VTune on my Vista PC, I experienced crash with some applications : Remote Desktop Connection and Solitaire, by example. Both are calling an interrupt procedure at initialization.
770E7DFE int 3
I can still run the application by skipping these interrupt function in a debugger, but it's very annoying to do it every time!
Sadly, uninstalling VTune did not solved the issue. Cananyone helpme with this?
Andrey_Pavlenko
I'd suggest you to check if your system has following env. vars set:
Cor_Enable_Profiling=1
COR_PROFILER={91663010-0D1E-4ABD-8F0C-0B4B84CCA809}
BISTRO_COLLECTORS_DO_CALLGRAPH=1
Ifany of them exists - remove them and reboot the system.
/Andy.
