When upgrading a Fedora 35 machine, the VTune RPM fails to install:
Running scriptlet: intel-oneapi-vtune-2022.3.0-195.x86_64 140/364
C compiler version: 11.3.1
Make version: 4.3
Kernel version: 5.17.6-200
Cleaning workspaces ...
Done
Building socperf driver ...
Skipping BTF generation for /opt/intel/oneapi/vtune/2022.3.0/sepdk/src/socperf/src/socperf3.ko due to unavailability of vmlinux
Done
Building sep driver ...
/opt/intel/oneapi/vtune/2022.3.0/sepdk/src/linuxos.c: In function ‘LINUXOS_Install_Hooks’:
/opt/intel/oneapi/vtune/2022.3.0/sepdk/src/linuxos.c:1301:11: error: implicit declaration of function ‘profile_event_register’ [-Werror=implicit-function-declaration]
1301 | err = profile_event_register(MY_UNMAP, &linuxos_exec_unmap_nb);
/opt/intel/oneapi/vtune/2022.3.0/sepdk/src/linuxos.c:95:18: error: ‘PROFILE_MUNMAP’ undeclared (first use in this function)
95 | #define MY_UNMAP PROFILE_MUNMAP
/opt/intel/oneapi/vtune/2022.3.0/sepdk/src/linuxos.c:1301:34: note: in expansion of macro ‘MY_UNMAP’
/opt/intel/oneapi/vtune/2022.3.0/sepdk/src/linuxos.c:95:18: note: each undeclared identifier is reported only once for each function it appears in
/opt/intel/oneapi/vtune/2022.3.0/sepdk/src/linuxos.c:94:18: error: ‘PROFILE_TASK_EXIT’ undeclared (first use in this function)
94 | #define MY_TASK PROFILE_TASK_EXIT
/opt/intel/oneapi/vtune/2022.3.0/sepdk/src/linuxos.c:1302:34: note: in expansion of macro ‘MY_TASK’
1302 | err2= profile_event_register(MY_TASK, &linuxos_exit_task_nb);
/opt/intel/oneapi/vtune/2022.3.0/sepdk/src/linuxos.c: In function ‘LINUXOS_Uninstall_Hooks’:
/opt/intel/oneapi/vtune/2022.3.0/sepdk/src/linuxos.c:1402:5: error: implicit declaration of function ‘profile_event_unregister’ [-Werror=implicit-function-declaration]
1402 | profile_event_unregister(MY_UNMAP, &linuxos_exec_unmap_nb);
/opt/intel/oneapi/vtune/2022.3.0/sepdk/src/linuxos.c:1402:30: note: in expansion of macro ‘MY_UNMAP’
/opt/intel/oneapi/vtune/2022.3.0/sepdk/src/linuxos.c:1403:30: note: in expansion of macro ‘MY_TASK’
1403 | profile_event_unregister(MY_TASK, &linuxos_exit_task_nb);
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:288: /opt/intel/oneapi/vtune/2022.3.0/sepdk/src/linuxos.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [Makefile:1841: /opt/intel/oneapi/vtune/2022.3.0/sepdk/src] Error 2
make: *** [Makefile:215: default] Error 2
Failed to build the drivers
Warning: the following driver(s) were not found loaded in the kernel: sep5.
Warning: no vtsspp driver was found loaded in the kernel.
Warning: no socwatch driver was found loaded in the kernel.
Warning: the following driver(s) were not found loaded in the kernel: socperf3.
The PAX service is not loaded anymore.
PYTHON is set to python
ERROR: sep5 driver "sep5-x32_64-5.17.6-200.fc35.x86_64smp.ko"
was not found in directory "." !
This means you may need to build sep5 driver from the provided
driver sources. Please see the driver README for instructions.
Note: Ensure that the driver is built for kernel version 5.17.6-200.fc35.x86_64
Configuring sep5 boot script with the following options:
driver files = /opt/intel/oneapi/vtune/2022.3.0/sepdk/src/.
Creating systemd load script /usr/local/sbin/sep5-load.sh ...
done.
Creating systemd boot config file /usr/lib/systemd/system/sep5.service ...
done.
Configuring autoload of sep5.service service ...
Job for sep5.service failed because the control process exited with error code.
See "systemctl status sep5.service" and "journalctl -xeu sep5.service" for details.
WARNING: systemctl start returned error 1 ...
done.
This error was observed on the following Linux kernel version: 5.17.12-200.fc35.x86_64.
See the following related issues for context: building sepdk driver, corrupted data file.
Thanks for posting in Intel Forum.
We are working on this. We will get back to you soon.
Janani Chandran
Linux kernel 5.17 removes callback mechanism for process exit notification and module unmap notification which the SEP driver uses to track dynamic process creation / termination and dynamic module load / unload, respectively, during collection.
The workaround for this issue will be available in Intel VTune Profiler 2022.4.
Is your issue resolved? Do you have any updates?
Janani Chandran
I get the same error while trying to build drivers are there solutions for this?
best
Aren
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
@Aren, Workaround for this issue will be available in vtune 2022.4.We will let you know once it is available.
Janani Chandran
Well, the issue is not resolved yet since I have to wait for 2022.4 but I will try again once that is released.
