Analyzers
VTune installation problem
Huang_J_
HI, when I'm installing VTune 2013 update 17, at the last step, an error log appeared shown below:
Warning:  no sep3_15 driver was found loaded in the kernel.
Checking for PMU arbitration service (PAX) ... not detected.
Attempting to start PAX service ...
Executing: insmod ./pax/pax-x32_64-3.13.0-32-genericsmp.ko
insmod: error inserting './pax/pax-x32_64-3.13.0-32-genericsmp.ko': -1 Unknown symbol in module
Error:  pax driver failed to load!
You may need to build pax driver for your kernel.
Please see the pax driver README for instructions.
Error: failed to start or connect to required PAX service
Can anyone help me out? Many thanks.
Huang_J_
Besides, I run the following command in /sepdk/src:
lsmod | grep pax
lsmod | grep sep
lsmod | grep vtsspp
I can not see anything.
Peter_W_Intel
You need to go vtune/sepdk/src, run (if you have Linux* kernel source installed.)
build-driver
insmod-sep3
However, I strongly suggest you to use latest VTune(TM) Amplifier XE 2015 u1 - since your kernel 3.13.0-32- is for latest OS, you need latest VTune to support latest OS.
Huang_J_
HI, Peter, thanks for your patience and response. I installed the latest VTune and problem solved.
Peter_W_Intel
Sounds good, thanks for the update.
