Analyzers
5316 Discussions
VTune's self-check fails on GPU Compute/Media Hotspots
Hrishi2407
I'm using
OS: Ubuntu 24.10
VTune: 2025.0.1
CPU: Intel(R) Core(TM) Ultra 7
GPU: Intel(R) Arc(TM) Graphics
After running "vtune-self-checker.sh"
Intel(R) VTune(TM) Profiler Self Check Utility
Copyright (C) 2009 Intel Corporation. All rights reserved.
Build Number: 629235
HW event-based analysis (counting mode) (Perf)
Example of analysis types: Performance Snapshot
    Collection: Ok
vtune: Error: Cannot stop collection of GPU events
    Finalization: Ok...
    Report: Ok
Instrumentation based analysis check
Example of analysis types: Hotspots and Threading with user-mode sampling
    Collection: Ok
    Finalization: Ok...
    Report: Ok
HW event-based analysis check (Perf)
Example of analysis types: Hotspots with HW event-based sampling, HPC Performance Characterization, etc.
    Collection: Ok
vtune: Warning: To profile kernel modules during the session, make sure they are available in the /lib/modules/kernel_version/ location.
vtune: Warning: Precise events are not available on this platform in the driverless mode and will be collected as non-precise. Some metrics may be less accurately attributed to the program code. Please consider loading VTune Profiler driver. Updating Linux kernel to newer version may also help.
    Finalization: Ok...
vtune: Warning: Cannot locate debugging information for the Linux kernel. Source-level analysis will not be possible. Function-level analysis will be limited to kernel symbol tables. See the Enabling Linux Kernel Analysis topic in the product online help for instructions.
    Report: Ok
Example of analysis types: Microarchitecture Exploration
    Collection: Ok
    Finalization: Ok...
    Report: Ok
HW event-based analysis with uncore events (Perf)
Example of analysis types: Memory Access
    Collection: Ok
    Finalization: Ok...
    Report: Ok
HW event-based analysis with stacks (Perf)
Example of analysis types: Hotspots with HW event-based sampling and call stacks
    Collection: Ok
    Finalization: Ok...
    Report: Ok
HW event-based analysis with context switches (Perf)
Example of analysis types: Threading with HW event-based sampling
    Collection: Ok
    Finalization: Ok...
    Report: Ok
Checking DPC++ application as prerequisite for GPU analyses: Fail
Unable to run DPC++ application on GPU connected to this system. If you are using an Intel GPU and want to verify profiling support for DPC++ applications, check these requirements:
* Install Intel(R) GPU driver.
* Install Intel(R) Level Zero GPU runtime.
* Install Intel(R) oneAPI DPC++ Runtime and set the environment.
The system is ready to be used for performance analysis with Intel VTune Profiler.
Review warnings in the output above to find product limitations, if any.
The system is ready for the following analyses:
* Performance Snapshot
* Hotspots and Threading with user-mode sampling
* Hotspots with HW event-based sampling, HPC Performance Characterization, etc.
* Microarchitecture Exploration
* Memory Access
* Hotspots with HW event-based sampling and call stacks
* Threading with HW event-based sampling
The following analyses have failed on the system:
* GPU Compute/Media Hotspots (characterization mode)
* GPU Compute/Media Hotspots (source analysis mode)
Log location: /tmp/vtune-tmp-user/self-checker-2025.03.07_05.36.40/log.txt
The drivers are loaded properly and SYCL programs run on the GPU, but VTune's self-check fails on GPU Compute/Media Hotspots. Any solutions to this?
yuzhang3_intel
Can you check the log file and see if the sycl8 library is missing? If yes, it means you need to install the Intel oneAPI DPC++/C++ compiler because the current self-check utility depends on the library located in the compiler.
When the sycl environment is ready, you need to install the GPU driver and compute runtime:
https://dgpu-docs.intel.com/driver/installation.html
https://github.com/intel/compute-runtime/releases
Mustafa_Ali
It seems like you're encountering a problem with VTune's self-check failing for GPU Compute/Media Hotspots even though your drivers are loaded and SYCL programs are running fine on the GPU. Based on the warnings and errors in the log, here are a few things you might try to resolve the issue:
  1. Ensure All Prerequisites Are Installed:
    • Double-check that you have all required drivers installed:
      • Intel GPU driver
      • Intel Level Zero GPU runtime
      • Intel oneAPI DPC++ Runtime
    • Make sure they are set up properly as per VTune’s instructions, especially for profiling DPC++ applications on your Intel GPU.
  2. Kernel Modules and Debugging Info:
    • There’s a warning indicating that VTune cannot find debugging information for the Linux kernel. This could limit some of VTune’s profiling capabilities. You might need to load specific kernel modules for complete support or install debugging symbols for the kernel if you need deeper analysis.
  3. VTune Profiler Driver:
    • It also mentions that precise events are not available in driverless mode and suggests loading the VTune Profiler driver. Try installing or loading the VTune profiler driver to ensure the profiling data is as accurate as possible. Additionally, check if updating your Linux kernel might resolve any issues related to event precision.
  4. Update Your Kernel:
    • The issue might be related to the version of your kernel. VTune may need an updated kernel to support more precise event-based profiling, especially for GPUs. Check if there are newer kernel versions available for Ubuntu that could help resolve the issue.
  5. Check VTune Logs:
    • Check the logs at /tmp/vtune-tmp-user/self-checker-2025.03.07_05.36.40/log.txt for any additional clues or errors that may help pinpoint the root cause.
Additionally, for more insights on optimizing GPU-related tasks, you might find this https://chatgptmodapk.com/  useful for finding solutions and detailed discussions on similar topics.
Hrishi2407
I previously mentioned that the drivers were loaded properly, but after running "sudo ./insmod-sep -q",I realized that some required VTune drivers are not loaded. Only pax and socperf3 are present while sep5, vtssp and socwatch2_15 are not loaded.
pax driver is loaded and owned by group "user" with file permissions "660".
socperf3 driver is loaded and owned by group "user" with file permissions "660".
sep5 driver is not loaded.
socwatch2_15 driver is not loaded.
vtsspp driver is not loaded.
I tried running "sudo ./build-driver"
C compiler to use: [ /bin/gcc ]
C compiler version: 14.2.0
Make command to use: [ /bin/make ]
Make version: 4.3
Kernel source directory: [ /lib/modules/6.11.0-19-generic/build ]
Kernel version: 6.11.0-19-generic
Cleaning workspaces ...
Done
Building socperf driver ...
warning: the compiler differs from the one used to build the kernel
  The kernel was built by: x86_64-linux-gnu-gcc-14 (Ubuntu 14.2.0-4ubuntu2) 14.2.0
  You are using:           gcc (Ubuntu 14.2.0-4ubuntu2) 14.2.0
Skipping BTF generation for /opt/intel/oneapi/vtune/2025.0/sepdk/src/socperf/src/socperf3.ko due to unavailability of vmlinux
Done
Building sep driver ...
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x35: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x36: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x37: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x3b: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x40: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x45: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x4a: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x4f: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x54: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x59: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x5e: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x63: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x68: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x6c: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x71: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x76: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x7b: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x80: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x85: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x8a: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x8c: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x8e: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x90: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x92: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x95: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x9a: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0x9d: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xa2: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xa3: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xa5: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xa7: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xaa: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xae: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xb3: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xb8: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xbd: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xc2: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xc7: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xcc: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xd1: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xd6: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xdb: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xe0: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xe5: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xea: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xef: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xf4: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xf8: unreachable instruction
/opt/intel/oneapi/vtune/2025.0/sepdk/src/sys64.o: warning: objtool: .text+0xf9: unreachable instruction
Skipping BTF generation for /opt/intel/oneapi/vtune/2025.0/sepdk/src/sep5.ko due to unavailability of vmlinux
Done
Building pax driver ...
Skipping BTF generation for /opt/intel/oneapi/vtune/2025.0/sepdk/src/pax/pax.ko due to unavailability of vmlinux
Done
Building vtsspp driver ...
make[1]: Entering directory '/opt/intel/oneapi/vtune/2025.0/sepdk/src/vtsspp'
Skipping BTF generation for /opt/intel/oneapi/vtune/2025.0/sepdk/src/vtsspp/vtsspp.ko due to unavailability of vmlinux
make[1]: Leaving directory '/opt/intel/oneapi/vtune/2025.0/sepdk/src/vtsspp'
Done
Building socwatch driver ...
Building drivers for Linux target
/lib/modules/6.11.0-19-generic/build will be used as the kernel build directory
Using alternate compiler '/bin/gcc'
Removing previously built driver and scripts from /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/drivers
mkdir: cannot create directory ‘/opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/drivers’: File exists
'-c /bin/gcc -l -k /lib/modules/6.11.0-19-generic/build' options will be used to build the SoCWatch driver
************ Building socwatch2_15-x32_64-6.11.0-19-genericsmp.ko driver ************
Using C compiler = /bin/gcc
Using kernel build dir = /lib/modules/6.11.0-19-generic/build
No module symvers file found
Using common inc dir = /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/../common/include
"/lib/modules/6.11.0-19-generic/build/include/linux/cpufreq.h" exists!
"/lib/modules/6.11.0-19-generic/build/include/linux/device/class.h" exists!
Using file name sw_driver
Make args = KERNEL_SRC_DIR=/lib/modules/6.11.0-19-generic/build CPUFREQ_FIX_BACKPORTED=1 CLASSCREATE_CHANGE_BACKPORTED=1 DO_DEBUG_BUILD=0 DO_PROFILING=0 COMMON_INC_DIR=/opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/../common/include MODULE_SYMVERS_FILE= FILE_NAME=sw_driver
make[1]: Entering directory '/opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver'
make -C /lib/modules/6.11.0-19-generic/build M=/opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver clean
make[2]: Entering directory '/usr/src/linux-headers-6.11.0-19-generic'
  CLEAN   /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/Module.symvers
make[2]: Leaving directory '/usr/src/linux-headers-6.11.0-19-generic'
make[1]: Leaving directory '/opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver'
DO_DRIVER_PROFILING=0
INCDIR_1=/opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/../common/include
make -C /lib/modules/6.11.0-19-generic/build M=/opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver modules PWD=/opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver
  CC [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_driver.o
  CC [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_hardware_io.o
  CC [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_output_buffer.o
/opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_output_buffer.c:200:9: warning: "MIN" redefined
  200 | #define MIN(x, y) ((x) <= (y) ? (x) : (y))
In file included from ./include/linux/kernel.h:28,
                 from ./include/linux/cpumask.h:11,
                 from ./arch/x86/include/asm/paravirt.h:21,
                 from ./arch/x86/include/asm/cpuid.h:62,
                 from ./arch/x86/include/asm/processor.h:19,
                 from ./arch/x86/include/asm/timex.h:5,
                 from ./include/linux/timex.h:67,
                 from ./include/linux/time32.h:13,
                 from ./include/linux/time.h:60,
                 from ./include/linux/stat.h:19,
                 from ./include/linux/module.h:13,
                 from /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/inc/sw_internal.h:70,
                 from /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_output_buffer.c:56:
./include/linux/minmax.h:329:9: note: this is the location of the previous definition
  329 | #define MIN(a,b) __cmp(min,a,b)
  CC [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_tracepoint_handlers.o
  CC [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_collector.o
  CC [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_mem.o
  CC [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_internal.o
  CC [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_file_ops.o
  CC [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_ops_provider.o
  CC [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_trace_notifier_provider.o
  CC [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_reader.o
  CC [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_telem.o
  CC [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_pmt.o
  CC [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_counter_list.o
  CC [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/./src/sw_pci.o
  LD [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.o
  MODPOST /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/Module.symvers
  CC [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.mod.o
  LD [M]  /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.ko
  BTF [M] /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.ko
Skipping BTF generation for /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.ko due to unavailability of vmlinux
************ Built drivers are copied to /opt/intel/oneapi/vtune/2025.0/sepdk/src/socwatch/drivers directory ************
Done
Done building the drivers
and "sudo ./insmod-sep -r -g user"
PYTHON is set to python3
Warning:  the following driver(s) were not found loaded in the kernel:  sep5.
Warning:  no vtsspp driver was found loaded in the kernel.
Warning:  no socwatch driver was found loaded in the kernel.
Removing socperf3 driver from the kernel ... done.
The socperf3 driver has been successfully unloaded.
Attempting to stop PAX service ...
Removing pax driver from the kernel ... done.
The pax driver has been successfully unloaded.
PAX service has been stopped.
Detecting Secure Boot status...
Secure Boot is disabled
---------------------    Loading PAX driver    ---------------------
Checking for PMU arbitration service (PAX) ... not detected.
Attempting to start PAX service ...
Executing: insmod ./pax/pax-x32_64-6.11.0-19-genericsmp.ko
Setting group ownership of devices to group "user" ... done.
Setting file permissions on devices to "660" ... done.
The pax driver has been successfully loaded.
---------------------  Loading SOCPERF driver  ---------------------
Checking for socperf driver ... not detected.
Attempting to start socperf service ...
Executing: insmod ./socperf/src/socperf3-x32_64-6.11.0-19-genericsmp.ko
The socperf3 driver has been successfully loaded.
---------------------    Loading SEP driver    ---------------------
Executing: insmod ./sep5-x32_64-6.11.0-19-genericsmp.ko sym_lookup_func_addr="ffffffff9762bb90"
insmod: ERROR: could not insert module ./sep5-x32_64-6.11.0-19-genericsmp.ko: Invalid parameters
ERROR: sep5 driver failed to load!
You may need to build sep5 driver for your kernel.
Please see the sep5 driver README for instructions.
How can I resolve this issue?
yuzhang3_intel
I'm not sure what happened in the current driver load process. Did you capture the dmesg log file? Maybe we can see something wrong from the file.
Hrishi2407
This is what the logs showed
[  163.614849] PAX: PMU arbitration service v1.0.2 has been started.
[  164.667142] socperf3_0: SocPerf Driver loading...
[  164.667146] socperf3_0: SocPerf Driver about to register chrdev...
[  164.667147] socperf3_0: SocPerf Driver: result of alloc_chrdev_region is 0
[  164.667148] socperf3_0: SocPerf Driver: major number is 234
[  164.667149] socperf3_0: SocPerf Driver: detected 8 CPUs in lwpmudrv_Load
[  164.667150] socperf3_0: SocPerf Driver: creating device socperf3!c...
[  164.667339] socperf3_0: PMU check enabled! F6.Mbd.S1 index=-1
[  164.667341] socperf3_0: No MMIO list information detected!
[  164.667342] socperf3_0: SocPerf Driver v3.0.0 has been loaded.
[  165.765716] sep5: disagrees about version of symbol pmt_telem_get_next_endpoint
[  165.765721] sep5: Unknown symbol pmt_telem_get_next_endpoint (err -22)
[  165.765744] sep5: disagrees about version of symbol pmt_telem_register_endpoint
[  165.765744] sep5: Unknown symbol pmt_telem_register_endpoint (err -22)
[  165.765811] sep5: disagrees about version of symbol pmt_telem_get_endpoint_info
[  165.765812] sep5: Unknown symbol pmt_telem_get_endpoint_info (err -22)
[  165.765836] sep5: disagrees about version of symbol pmt_telem_read
[  165.765837] sep5: Unknown symbol pmt_telem_read (err -22)
yuzhang3_intel
Please follow the steps below to disable PMT and rebuild the driver:
Steps to disable PMT:
  1. Open /opt/intel/sep/sepdk/src/build-driver
  2. Updated line 122 from "BUILD_PMT="YES"" to "BUILD_PMT="NO""
  3. Build and load the driver using the regular steps
Hrishi2407
The sep5 and vtsspp drivers are loading now but still having issues with the socwatch driver
Executing: insmod ./sep5-x32_64-6.11.0-19-genericsmp.ko sym_lookup_func_addr="ffffffffb7e2bb90"
The sep5 driver has been successfully loaded.
---------------------  Loading VTSSPP driver  ---------------------
Checking for vtsspp driver ... not detected.
Executing: insmod ./vtsspp/vtsspp-x32_64-6.11.0-19-genericsmp.ko gid=1000 mode=0660 ksyms="ffffffffb7e2bb90"
The vtsspp driver has been successfully loaded.
--------------------- Loading SOCWATCH driver ---------------------
Checking for socwatch driver ... not detected.
Executing: insmod ./socwatch/drivers/socwatch2_15-x32_64-6.11.0-19-genericsmp.ko
insmod: ERROR: could not insert module ./socwatch/drivers/socwatch2_15-x32_64-6.11.0-19-genericsmp.ko: Invalid parameters
Error: socwatch2_15-x32_64-6.11.0-19-genericsmp driver failed to load!
You may need to build socwatch2_15-x32_64-6.11.0-19-genericsmp driver for your kernel.
Please see the socwatch2_15-x32_64-6.11.0-19-genericsmp driver README for instructions.
yuzhang3_intel
Please post the output of the command line below:
$ lsmod | grep socwatch
Hrishi2407
It did not return any output
yuzhang3_intel
Actually, the driver is only for package power collection, you can ignore it if you don't need it. For CPU profiling, sep/vtsspp driver are enough.
Hrishi2407
Understood, but I also require package power monitoring alongside CPU/GPU profiling.
yuzhang3_intel
This is one known issue, which is fixed in the coming 2025.1 release.
I am not sure if you can insmod the ko file manually in the path below, and execute the command line: ./insmod-socwatch -r -g vtune (the same group as VTune)
.....sepdk/src/socwatch/drivers
Hrishi2407
It seems I'm unable to insmod the ko file manually
Hrishi2407
It seems even after the sep5 and vtsspp drivers loading successfully, the main issue still persists
* Memory Access
yuzhang3_intel
Can you check the self check log file and see if the sycl8 library is missing? If yes, it means you need to install the Intel oneAPI DPC++/C++ compiler because the current self-check utility depends on the library located in the compiler.
Hrishi2407
I installed the Intel oneAPI DPC++/C++ compiler and after running self check and "cat /tmp/vtune-tmp-user/self-checker-2025.03.19_06.42.09/log.txt | grep -i "missing\|error\|sycl\|sycl8" ":
  i915Status: MissingDriver
  isFtraceAvailable: ftraceAccessError,debugfsNotAccessible
  vtune: Error: Error 0x4000002a (Database interface error) -- Cannot run data transformation `Conditional GPU metric'.
sycl-ls
  SYCL_PI_TRACE has been removed use SYCL_UR_TRACE instead
Also I got VTune from the Intel oneAPI Base Toolkit so the compiler should not be an issue
yuzhang3_intel
See the output of the command line:
$ sycl-ls
If oneAPI DPC++ environment is ready, you should see something below:
yuzhang3@yuzhang3-10710:~/yuzhang3/win_bk/MyDocuments/MyProject/PrjData/project$ sycl-ls
[level_zero:gpu][level_zero:0] Intel(R) oneAPI Unified Runtime over Level-Zero, Intel(R) UHD Graphics 9.7.0 [1.3.28202]
[opencl:cpu][opencl:0] Intel(R) OpenCL, Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz OpenCL 3.0 (Build 0) [2024.18.10.0.08_160000]
[opencl:gpu][opencl:1] Intel(R) OpenCL Graphics, Intel(R) UHD Graphics OpenCL 3.0 NEO [23.52.28202.52]
Hrishi2407
Sycl is able to access the gpu but VTune isn't able to
[level_zero:gpu][level_zero:0] Intel(R) oneAPI Unified Runtime over Level-Zero, Intel(R) Arc(TM) Graphics 20.4.4 [1.6.32224+14]
[opencl:cpu][opencl:0] Intel(R) OpenCL, Intel(R) Core(TM) Ultra 7 258V OpenCL 3.0 (Build 0) [2024.18.12.0.05_160000]
[opencl:gpu][opencl:1] Intel(R) OpenCL Graphics, Intel(R) Arc(TM) Graphics OpenCL 3.0 NEO  [24.52.32224]
yuzhang3_intel
Run the test app in VTune installation folder:
yuzhang3@yuzhang3-10710:/opt/intel/oneapi/vtune/latest/bin64/self_check_apps/matrix.dpcpp$ ./matrix.dpcpp
Address of buf1 = 0x76ec74400010
Offset of buf1 = 0x76ec74400180
Address of buf2 = 0x76ec73a00010
Offset of buf2 = 0x76ec73a001c0
Address of buf3 = 0x76ec73000010
Offset of buf3 = 0x76ec73000100
Address of buf4 = 0x76ec72600010
Offset of buf4 = 0x76ec72600140
Using multiply kernel: multiply1
Available devices:
* Running on Intel(R) UHD Graphics
No subdevices available, using the whole device
* Finished *
Elapsed Time: 0.531978s
Hrishi2407
These were the results:
Address of buf1 = 0x7855b21ff010
Offset of buf1 = 0x7855b21ff180
Address of buf2 = 0x7855b19fe010
Offset of buf2 = 0x7855b19fe1c0
Address of buf3 = 0x7855b11fd010
Offset of buf3 = 0x7855b11fd100
Address of buf4 = 0x7855b09fc010
Offset of buf4 = 0x7855b09fc140
Available devices:
* Running on Intel(R) Arc(TM) Graphics
* Finished *
Elapsed Time: 0.354231s
