Analyzers
Very slow execution Inspector Linux
Garbin__Fabio
I'm using Intel(R) Inspector 2017 Update 1 (build 484836) Command Line tool to find a memory corruption an application server, but I can't finish the test with inspector because it take a lot of time, about hours for single execution.
I try to use the collection-with option and with this option just test for leaks problems and don't to memory access problems.
Below is some line commands that i try, just the # 2 end the execution.
1) inspxe-cl --collect mi3 -- /home/fg/p11/bin/appserverx64/appsrvlinux
2) nspxe-cl -collect-with runmc -knob enable-memory-growth-detection=false -knob enable-guard-zones=true -knob enable-on-demand-leak-detection=false -knob detect-leaks-on-exit=false  -- /home/fg/p11/bin/appserverx64/appsrvlinux
3) inspxe-cl -collect mi2 -knob enable-on-demand-leak-detection=false -- /home/fg/p11/bin/appserverx64/appsrvlinux
Is there some option to just run memory access problems ?
Kevin_O_Intel1
Yes.... we have api's that allow you to control what portions of your app are analyzed.
https://software.intel.com/en-us/inspector-user-guide-linux-apis-for-collection-control
The main recommendation I would give is to try to analyze on the smallest subset of the problem that you can.
