Analyzers
5279 Discussions
Vtune collect hotspots error on WSL : option pmu-type received value from the nex argument
louisc
I tried using the Vtune utility on WSL. Hardware counters were not detected, which seems pretty normal to me. However the software mode is not usable neither because some option is not correctly given :
> vtune: Error: Option 'pmu-type' received value from the next argument: '--event-config=CPU_CLK_UNHALTED.T
Any clue on how to fix this ?
>/opt/intel/oneapi/vtune/latest/bin64/vtune-self-checker.sh
Intel(R) VTune(TM) Profiler Self Check Utility
Copyright (C) 2009 Intel Corporation. All rights reserved.
Build Number: 630424
HW event-based analysis (counting mode)
Example of analysis types: Performance Snapshot
    Collection: Fail
vtune: Error: This analysis type is not applicable to the system because VTune Profiler cannot recognize the processor. If this is an old Intel processor, please refer to the minimum hardware requirements in the release note. If this is a new Intel processor, please check for an updated version of VTune Profiler. If this is an unreleased Intel processor, please contact Online Service Center for an NDA product package.
vtune: Error: This analysis type is not applicable to the current machine microarchitecture.
Instrumentation based analysis check
Example of analysis types: Hotspots and Threading with user-mode sampling
    Collection: Fail
vtune: Error: Option 'pmu-type' received value from the next argument: '--event-config=CPU_CLK_UNHALTED.THREAD,CPU_CLK_UNHALTED.REF_TSC:sample:sa=3600000,INST_RETIRED.ANY:sample:sa=3600000,CPU_CLK_UNHALTED.DISTRIBUTED,UOPS_RETIRED.RETIRE_SLOTS:sample:sa=2000003', but it seems to be an option. Use '-option=value' declaration form or make sure that value is not missed
[...] same errors beyond this point
optimizergal
User-mode sampling automatically enables the collection of "additional performance insights," which uses hardware counters to get some vectorization info. It shouldn't prevent the analysis if the counters aren't available, but in this case it still seems to try anyway. Maybe it's something specific to WSL. I've always felt that this option should be disabled by default in user-mode sampling because it's confusing.
I don't know if you can disable them with an argument in vtune-self-checker.sh, but if you run your user-mode sampling analysis with the option -knob enable-characterization-insights=false then it should work. For example:
vtune -collect hotspots -knob enable-characterization-insights=false -- myapp
louisc
I was not aware of this option but can confirm that it makes the "hotspots" collection works in my use case.
It is indeed a bit surprising that it uses hardware counters in the sw mode.
Anyway, thanks a lot !
