Analyzers
5280 Discussions
Vtune crashes after sampling collection is done
alex_belousov
we develop high performace multithreaded application and I try to evaluate vtune for performance checking. if I run our utility under Vtune in a single threaded mode - it runs fine. If I use 6 threads it vtune dies somwhere in java. Please advise:
===== BEGIN DUMP =============================================================
JRockit dump produced after 0 days, 00:09:15 on Tue Jul 28 11:46:42 2009
Additional information is available in:
/home/belousov/workspace1/jrockit.23731.dump
No snapshot file (core dump) will be created because core dumps have been
disabled. To enable core dumping, try "ulimit -c unlimited"
before starting JRockit again.
If you see this dump, please open a support case with BEA and
supply as much information as you can on your system setup and
the program you were running. You can also search for solutions
to your problem at http://forums.bea.com in
the forum jrockit.developer.interest.general.
Error Message: Illegal memory access. [54]
Signal info : si_signo=11, si_code=2 si_addr=(nil)
Version : BEA JRockit R27.2.0-131-78843-1.5.0_10-20070320-1511-linux-ia32
GC Mode : Garbage collection optimized for throughput
GC Strategy : Generational Parallel Mark & Sweep
: Current OC phase is: not running. YC is not running.
: GC strategy for GC 0 was singleconcon
: GC strategy for GC 1 was genparpar
: GC strategy for GC 2 was genparpar
: mmHeap->data = 0x8100000, mmHeap->top = 0xc100000
: The nurserylist starts at 0x82984a0 and ends at 0xa5a51e8
: mmStartCompaction = 0x8100000, mmEndCompaction = 0x8500000
: References are 32-bit.
CPU : Intel Pentium M model D SSE SSE2 SSE3 SSSE3 EM64T
Number CPUs : 16
Tot Phys Mem : 67580878848 (64450 MB)
OS version : Red Hat Enterprise Linux WS release 4 (Nahant Update 7)
Linux version 2.6.9-78.ELlargesmp (brewbuilder@ls20-bc2-14.build.redhat.com) (gcc version 3.4.6 20060404 (Red Hat 3.4.6-10)) #1 SMP Wed Jul 9 16:03:59 EDT 2008 (x86_64)
Thread System: NPTL
State : JVM is running
Command Line : -Dosgi.splashLocation=/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/com.intel.sdp.primary_2.0.4/splash.bmp -Dosgi.sharedConfiguration.area=/opt/intel/vtune/bin/../shared/eclipse/configuration -Dsun.java.launcher=SUN_STANDARD /opt/intel/eclipsepackage/3.2.1/eclipse/startup.jar -os linux -ws gtk -arch x86-launcher /opt/intel/eclipsepackage/3.2.1/eclipse/eclipse -name Eclipse -showsplash 600 -exitdata 840010 -product com.intel.sdp.primary.product -perspective com.intel.vtune.shell.tuningPerspective -vm /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/bin/java -vmargs -Dosgi.splashLocation=/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/com.intel.sdp.primary_2.0.4/splash.bmp -Dosgi.sharedConfiguration.area=/opt/intel/vtune/bin/../shared/eclipse/configuration -jar /opt/intel/eclipsepackage/3.2.1/eclipse/startup.jar
java.home : /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10
j.class.path : /opt/intel/eclipsepackage/3.2.1/eclipse/startup.jar
j.lib.path : /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/jrockit:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/../lib/i386:/opt/intel/eclipsepackage/3.2.1/eclipse:/opt/intel/vtune/analyzer/bin:/opt/intel/vtune/shared/bin:/opt/sag/gcc-3.4/libem64t:/opt/sag/gcc-3.3/lib32:/opt/sag/gcc-3.3/lib32:/opt/sag/exx/v721/lib:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/share/oa/lib/linux_rhel30_gcc411_64/opt:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/tools.lnx86/lib/64bit:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/tools.lnx86/lib:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/tools.lnx86/QT/lib:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/tools.lnx86/QT/lib/64bit:/usr/lib:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/share/oa/lib/linux_rhel30_gcc411_64/opt:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/tools.lnx86/lib/64bit:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/tools.lnx86/lib:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/tools.lnx86/QT/lib:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/tools.lnx86/QT/lib/64bit
JAVA_HOME :
_JAVA_OPTIONS:
LD_LIBRARY_PATH: /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/jrockit:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/../lib/i386:/opt/intel/eclipsepackage/3.2.1/eclipse:/opt/intel/vtune/analyzer/bin:/opt/intel/vtune/shared/bin:/opt/sag/gcc-3.4/libem64t:/opt/sag/gcc-3.3/lib32:/opt/sag/gcc-3.3/lib32:/opt/sag/exx/v721/lib:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/share/oa/lib/linux_rhel30_gcc411_64/opt:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/tools.lnx86/lib/64bit:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/tools.lnx86/lib:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/tools.lnx86/QT/lib:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/tools.lnx86/QT/lib/64bit:/usr/lib:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/share/oa/lib/linux_rhel30_gcc411_64/opt:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/tools.lnx86/lib/64bit:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/tools.lnx86/lib:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/tools.lnx86/QT/lib:/export/home/belousov/masco_sb_latest/output/cdn_hier/lnx86/tools.lnx86/QT/lib/64bit
LD_ASSUME_KERNEL:
C Heap : Good; no memory allocations have failed
StackOverFlow: 0 StackOverFlowErrors have occured
OutOfMemory : 0 OutOfMemoryErrors have occured
Registers (from ThreadContext: 0xffff342c / OS context: 0xffff3528):
eax = 00000000 ecx = 003ea668 edx = 852c8628 ebx = ed9136c4
esp = ffff3818 ebp = ffff3854 esi = eb1fb8c0 edi = 00000000
es = 0000002b cs = 00000023 ss = ffff002b ds = 0000002b
fs = 00000003 gs = 0000005b
eip = ed9091ff eflags = 00200246
Stack:
(* marks the word pointed to by the stack pointer)
ffff3818: eb1fb8c0* f556d1e0 00000003 00000000 ed9136c4 eb1f7030
ffff3830: ed913840 ffff3c30 ed8e21d0 f556d150 f6e59910 00000000
ffff3848: 006e1a96 f556d1e0 ed913840 ffff3878 ed9080c1 f6e59910
ffff3860: f6e59910 ed9136c4 ffff38c8 ffff3a80 00000000 eb1f7030
Code:
(* marks the word pointed to by the instruction pointer)
ed9091cc: e85589f0 8bec4d89 8b50f855 70ffe845 f1e85204 8bffffdb
ed9091e4: 34bb8df0 56000001 8b20568b 3f8b244e 1246b70f ff253f8b
ed9091fc: 2b00000f* 4c1bc714 458b04c7 b09089fc 89000001 0001b488
ed909214: ac808300 01000001 ffd973e8 ec458bff 49e85056 83ffffdc
Loaded modules:
(* denotes the module causing the exception)
08048000-08056fd3 /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/bin/java
ffffe000-ffffe7bf /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/bin/java
00a21000-00a2e85b /lib/tls/libpthread.so.0
009fc000-00a1cc8f /lib/tls/libm.so.6
009f6000-009f7967 /lib/libdl.so.2
008c5000-009ed590 /lib/tls/libc.so.6
008a6000-008bb44b /lib/ld-linux.so.2
f7cae000-f7f4d207 /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/jrockit/libjvm.so
f7c65000-f7c6ca76 /lib/tls/librt.so.1
f7ff1000-f7ffb7db /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/libverify.so
f7fce000-f7fee217 /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/libjava.so
f7bb3000-f7bc566f /lib/libnsl.so.1
f7a7c000-f7a81f13 /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/native_threads/libhpi.so
f7383000-f73914c4 /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/libzip.so
f6eed000-f6efe0a3 /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/libnet.so
f6ee5000-f6eeb1e7 /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/libnio.so
f6833000-f687ce1b /home/belousov/.eclipse/org.eclipse.platform_3.2.0/configuration/org.eclipse.osgi/bundles/68/1/.cp/libswt-pi-gtk-3235.so
f657f000-f6826ecf /usr/lib/libgtk-x11-2.0.so.0
00a35000-00a37e87 /usr/lib/libgthread-2.0.so.0
f6546000-f6549c8f /usr/X11R6/lib/libXtst.so.6
f6531000-f65443fb /usr/lib/libgdk_pixbuf-2.0.so.0
f64c5000-f652b70f /usr/lib/libgdk-x11-2.0.so.0
f63e6000-f64c08e7 /usr/X11R6/lib/libX11.so.6
f63e1000-f63e4a93 /usr/lib/libpangoxft-1.0.so.0
f63d6000-f63df8fb /usr/lib/libpangox-1.0.so.0
f63a0000-f63d04c3 /usr/lib/libpango-1.0.so.0
f6386000-f639dfcb /usr/lib/libatk-1.0.so.0
f634a000-f63833eb /usr/lib/libgobject-2.0.so.0
008c0000-008c1fb3 /usr/lib/libgmodule-2.0.so.0
f62cf000-f6348c33 /usr/lib/libglib-2.0.so.0
f62c1000-f62cd13f /usr/X11R6/lib/libXext.so.6
f62be000-f62bff57 /usr/X11R6/lib/libXrandr.so.2
f62b6000-f62bc4f7 /usr/X11R6/lib/libXi.so.6
f62b3000-f62b433f /usr/X11R6/lib/libXinerama.so.1
f62a1000-f62b132b /usr/X11R6/lib/libXft.so.2
f6236000-f629959b /usr/lib/libfreetype.so.6
f6210000-f6231883 /usr/lib/libfontconfig.so.1
f6207000-f620e20b /usr/X11R6/lib/libXcursor.so.1
f61ff000-f6205793 /usr/X11R6/lib/libXrender.so.1
f61d9000-f61fda4f /usr/lib/libpangoft2-1.0.so.0
f61ba000-f61d68b3 /usr/lib/libexpat.so.0
f61aa000-f61b8ba3 /usr/lib/libz.so.1
f6577000-f65777b7 /usr/X11R6/lib/X11/locale/lib/common/xlcUTF8Load.so.2
f6172000-f6172d67 /usr/lib/gconv/ISO8859-1.so
f6149000-f616e073 /home/belousov/.eclipse/org.eclipse.platform_3.2.0/configuration/org.eclipse.osgi/bundles/68/1/.cp/libswt-gtk-3235.so
f613c000-f6147103 /usr/lib/gtk-2.0/2.4.0/engines/libbluecurve.so
f5ef9000-f5efa293 /home/belousov/.eclipse/org.eclipse.platform_3.2.0/configuration/org.eclipse.osgi/bundles/17/1/.cp/os/linux/x86/liblocalfile_1_0_0.so
f5afd000-f5afe257 /usr/lib/pango/1.4.0/modules/pango-basic-fc.so
f59e4000-f59e920f /home/belousov/.eclipse/org.eclipse.platform_3.2.0/configuration/org.eclipse.osgi/bundles/68/1/.cp/libswt-atk-gtk-3235.so
f59a4000-f59e2b1b /home/belousov/.eclipse/org.eclipse.platform_3.2.0/configuration/org.eclipse.osgi/bundles/68/1/.cp/libcairo-swt.so
f599a000-f59a2e87 /home/belousov/.eclipse/org.eclipse.platform_3.2.0/configuration/org.eclipse.osgi/bundles/68/1/.cp/libswt-cairo-gtk-3235.so
f4cd8000-f4cdb5e3 /opt/intel/vtune/shared/bin/libEcGUIClientHandler.so
f4c2a000-f4ca738f /opt/intel/vtune/shared/bin/libEcGUIClient.so
f4a85000-f4c27e07 /opt/sag/gcc-3.3/lib32/libimf.so
f4a83000-f4a83577 /opt/sag/gcc-3.3/lib32/libcxaguard.so.5
f4a7b000-f4a81f1f /opt/sag/gcc-3.3/lib32/libgcc_s.so.1
f49c3000-f4a60393 /opt/sag/gcc-3.3/lib32/libstdc++.so.5
f482a000-f4996343 /opt/sag/exx/v721/lib/libole32.so
f476b000-f4816dab /opt/sag/exx/v721/lib/librpcrt4.so
f4749000-f4763733 /opt/sag/exx/v721/lib/libntrtl.so
f46b7000-f4733183 /opt/sag/exx/v721/lib/libmutant.so
f46af000-f46b4b27 /opt/sag/exx/v721/lib/libcoolmisc.so
f45cb000-f469b8af /opt/sag/exx/v721/lib/liboleaut32.so
f4538000-f45c1db3 /opt/intel/vtune/analyzer/bin/libcomfreeremoteconnector.so
f450c000-f452d023 /opt/intel/vtune/shared/bin/libVTUtil.so
f4507000-f4509ec3 /opt/sag/exx/v721/lib/libcoolcrypto.so
f40b3000-f43b79ab /opt/intel/vtune/shared/bin/libxerces-c.so.23
f407f000-f40ac547 /opt/intel/vtune/shared/bin/libRemoteManager.so
f4078000-f407cc03 /opt/sag/exx/v721/lib/libbasecrypt.so
f4061000-f4071cff /opt/intel/vtune/shared/bin/libVTRegLoc.so
f3ff2000-f3ffaa57 /lib/libnss_files.so.2
f3d7c000-f3f9a7ff /lib/libnss_ldap.so.2
f3d79000-f3d7a04b /lib/libcom_err.so.2
f3d66000-f3d74fef /lib/libresolv.so.2
f3293000-f332ad9f /opt/intel/vtune/shared/bin/libShell.so
f3289000-f3290ed7 /opt/intel/vtune/shared/bin/libShellRes.so
f2e4c000-f2e75eaf /opt/intel/vtune/shared/bin/libReports.so
f2e45000-f2e49db7 /opt/intel/vtune/shared/bin/libReportsRes.so
f2e22000-f2e3a4eb /opt/intel/vtune/shared/bin/libComInfo.so
f2dda000-f2e0becf /opt/intel/vtune/shared/bin/libProductInfo.so
f2dd4000-f2dd7537 /opt/intel/vtune/shared/bin/libProductInfoRes.so
f2cc6000-f2d813e3 /opt/intel/vtune/shared/bin/libWorkspaceMgr.so
f2cbf000-f2cc32b7 /opt/intel/vtune/shared/bin/libWorkspaceMgrRes.so
f2c55000-f2c9d39b /opt/intel/vtune/shared/bin/libCollection.so
f2c4f000-f2c525b7 /opt/intel/vtune/shared/bin/libCollectionRes.so
f2ac4000-f2bd3713 /opt/intel/vtune/shared/bin/libActivity.so
f2aba000-f2ac13f7 /opt/intel/vtune/shared/bin/libActivityRes.so
f2a79000-f2aa348b /opt/intel/vtune/shared/bin/libFileDialog.so
f2a47000-f2a6a28b /opt/intel/vtune/shared/bin/libFileDialogEc.so
f29fe000-f2a2fe8f /opt/intel/vtune/shared/bin/libFileMgr.so
f29f8000-f29fbcb7 /opt/intel/vtune/shared/bin/libFileMgrRes.so
f293d000-f29be563 /opt/intel/vtune/shared/bin/libTuningBrowser.so
f2935000-f293a217 /opt/intel/vtune/shared/bin/libTuningBrowserRes.so
f289e000-f29040d3 /opt/intel/vtune/shared/bin/libWorkspaceUI.so
f2896000-f289b277 /opt/intel/vtune/shared/bin/libWorkspaceUIRes.so
f282a000-f2874f3f /opt/intel/vtune/analyzer/bin/libCGAddin.so
f27cb000-f280e77b /opt/intel/vtune/analyzer/bin/libAnPropContainers.so
f2767000-f27ae123 /opt/intel/vtune/analyzer/bin/libCGCons4VT.so
f25a1000-f26d544b /opt/intel/vtune/shared/bin/libidvcbase.so
f24b8000-f255d6fb /opt/intel/vtune/analyzer/bin/libCGConsCore.so
f24b1000-f24b5daf /opt/intel/vtune/analyzer/bin/libCGPropStorage.so
f2478000-f24a0ef3 /opt/intel/vtune/analyzer/bin/libCGDataModelVTDBC.so
f23c6000-f24460a7 /opt/intel/vtune/shared/bin/libidvcfrw.so
f23ac000-f23be50f /opt/intel/vtune/shared/bin/libidvcpilot.so
f221f000-f2339c3f /opt/intel/vtune/shared/bin/libidvgrid.so
f2213000-f221b3af /opt/intel/vtune/analyzer/bin/libVTDBRuntime.so
f2203000-f220e377 /opt/intel/vtune/analyzer/bin/libCGPruner.so
f21e0000-f21f8e0f /opt/intel/vtune/analyzer/bin/libVTDBC.so
f217f000-f21c33d3 /opt/intel/vtune/analyzer/bin/libCGDP_VTDBC.so
f213f000-f21748bf /opt/intel/vtune/shared/bin/libigvlayout.so
f2091000-f2101c87 /opt/intel/vtune/shared/bin/libigvviewer.so
f207a000-f208a457 /opt/intel/vtune/shared/bin/libigvgraph.so
f2070000-f207646b /opt/intel/vtune/shared/bin/libigvdatamanager.so
f200c000-f2054c03 /opt/intel/vtune/analyzer/bin/libvtsdb.so
f1f99000-f1fecc8b /opt/intel/vtune/analyzer/bin/libCTCG.so
f1f8f000-f1f958c3 /opt/intel/vtune/shared/bin/libdbmanager.so
f1f54000-f1f7d85b /opt/intel/vtune/analyzer/bin/libSymbolProvider_VTDBC.so
f1de3000-f1ee7893 /opt/intel/vtune/shared/bin/libismImpl_2.so
f1d9b000-f1dda757 /opt/intel/vtune/shared/bin/libcommon_2.so
f1c37000-f1c4f40b /opt/intel/vtune/shared/bin/libsupport_2.so
f1c21000-f1c2f8c7 /opt/intel/vtune/shared/bin/libdtlu_trace_assert.so
f1a9b000-f1ad6857 /opt/intel/vtune/shared/bin/libvtfamgr.so
f1a8f000-f1a9724f /opt/intel/vtune/shared/bin/libVTAddr_2.so
f1a31000-f1a7182b /opt/intel/vtune/shared/bin/libSymVSrvr.so
f1a05000-f1a231f7 /opt/intel/vtune/shared/bin/libDynamicLoading_2.so
f1981000-f19e2253 /opt/intel/vtune/analyzer/bin/libCGImpExp.so
f196d000-f197a9bb /opt/intel/vtune/analyzer/bin/libVTSDBUtil.so
f18d8000-f1942a03 /opt/intel/vtune/analyzer/bin/libCGPackNGo.so
f1871000-f18b863f /opt/intel/vtune/shared/bin/libFileSearchAddIn.so
f17a0000-f182d1e3 /opt/intel/vtune/shared/bin/libvtfilehandler.so
f176c000-f17901f7 /opt/intel/vtune/analyzer/bin/libAnalyzerWizardsAddin.so
f16b7000-f17484d3 /opt/intel/vtune/analyzer/bin/libAnProdInfo.so
f16b0000-f16b44f7 /opt/intel/vtune/analyzer/bin/libAnProdInfoRes.so
f1678000-f169ef17 /opt/intel/vtune/analyzer/bin/libEcAnalyzerUtils.so
f1613000-f165afe7 /opt/intel/vtune/analyzer/bin/libSVConsumerEc.so
f15fe000-f160d0db /opt/intel/vtune/analyzer/bin/libsv_vtune_u.so
f15d9000-f15f3a3f /opt/intel/vtune/analyzer/bin/libsvpropstorage_u.so
f1501000-f159ee1f /opt/intel/vtune/analyzer/bin/libsvcore_u.so
f14cd000-f14f135f /opt/intel/vtune/analyzer/bin/libsvcontrol_u.so
f14b7000-f14c659f /opt/intel/vtune/analyzer/bin/libVtGridCtlLite_u.so
f12f0000-f142549b /opt/intel/vtune/shared/bin/libidvcbase_u.so
f11a7000-f11de9b7 /opt/intel/vtune/shared/bin/libdtlu_file.so
f1113000-f11848bb /opt/intel/vtune/analyzer/bin/libsvdp.so
f1102000-f110d54f /opt/intel/vtune/analyzer/bin/libsv_pi.so
f0f72000-f108eab7 /opt/intel/vtune/shared/bin/libidvgrid_u.so
f0f20000-f0f5819f /opt/intel/vtune/shared/bin/libidvtextviewer_u.so
f0f00000-f0f1662b /opt/intel/vtune/analyzer/bin/liblipsdp.so
f0ec1000-f0eed297 /opt/intel/vtune/analyzer/bin/libsv_dedp.so
f0eae000-f0ebb207 /opt/intel/vtune/analyzer/bin/libsv_do.so
f0e98000-f0ea7c2f /opt/intel/vtune/analyzer/bin/libsv_mh.so
f0c3d000-f0c72eff /opt/intel/vtune/analyzer/bin/liblips.so
f0c28000-f0c360d7 /opt/intel/vtune/analyzer/bin/libsv_ei.so
f0c21000-f0c264ff /opt/intel/vtune/analyzer/bin/libbemrl.so
f0c00000-f0c09d2f /opt/intel/vtune/analyzer/bin/libemrlcore.so
f0b84000-f0ba00f8 /opt/intel/vtune/analyzer/bin/libdecem.so
f0b70000-f0b7f693 /opt/intel/vtune/analyzer/bin/libdisem.so
f0b54000-f0b6635c /opt/intel/vtune/analyzer/bin/libdasm.so
f0b46000-f0b522bf /opt/intel/vtune/analyzer/bin/libdisxsc.so
f0b37000-f0b43a5f /opt/intel/vtune/analyzer/bin/libdecxsc.so
f0ad6000-f0b35133 /opt/intel/vtune/analyzer/bin/libdecoder.so
f0a50000-f0aaea23 /opt/intel/vtune/analyzer/bin/libSamplingConsumerEc.so
f086d000-f09c1567 /opt/intel/vtune/analyzer/bin/libSamplingViewerCore.so
f07bb000-f083b25f /opt/intel/vtune/shared/bin/libidvcfrw_u.so
f05d6000-f0681eb7 /opt/intel/vtune/shared/bin/libidvtimeline_u.so
f0558000-f05b30ff /opt/intel/vtune/shared/bin/libidvchart_u.so
f0515000-f0546a27 /opt/intel/vtune/shared/bin/libidvchartelements_u.so
f02e9000-f04690db /opt/intel/vtune/analyzer/bin/libSPLMDEDataMgr.so
f0281000-f02cdeaf /opt/intel/vtune/analyzer/bin/libVTDBJoin.so
f0256000-f027419f /opt/intel/vtune/analyzer/bin/libSamplingPropContainersEc.so
f00e4000-f01e9caf /opt/intel/vtune/analyzer/bin/libModuleHandler.so
eff7f000-effc3657 /opt/intel/vtune/analyzer/bin/libRatiosEditor.so
eff5d000-eff76d0b /opt/intel/vtune/analyzer/bin/libEvents.so
efef3000-eff3e9af /opt/intel/vtune/shared/bin/libActivityEc.so
efea3000-efedd4ef /opt/intel/vtune/analyzer/bin/libCGPreferencePagesEC.so
efe57000-efe8bde7 /opt/intel/vtune/shared/bin/libFileSearchPrefPagesEc.so
efe22000-efe4744f /opt/intel/vtune/analyzer/bin/libSVPreferencePagesEC.so
efdab000-efe00a3f /opt/intel/vtune/analyzer/bin/libSamplingPreferencesPagesEc.so
efd53000-efd9080f /opt/intel/vtune/analyzer/bin/libVTMHPrefPagesEc.so
ef4c4000-ef52750b /opt/intel/vtune/shared/bin/libVTRun.so
ef4bd000-ef4c1d17 /opt/intel/vtune/shared/bin/libVTRunRes.so
ef4a0000-ef4b358b /opt/sag/exx/v721/lib/libsecurity.so
ee066000-ee08babf /opt/intel/vtune/shared/bin/libPropBag.so
edff8000-ee0432df /opt/intel/vtune/shared/bin/libEnvInfo.so
edff3000-edff6a17 /opt/intel/vtune/shared/bin/libcpuinfo2.so.1
edfec000-edff048f /opt/intel/vtune/shared/bin/libcpuinfoxsc.so.1
edfe4000-edfe9d37 /opt/intel/vtune/shared/bin/libEnvInfoRes.so
efc19000-efc42f3b /opt/intel/vtune/shared/bin/libDataObject.so
efbf4000-efc0fb97 /opt/intel/vtune/analyzer/bin/libAnalyzerResources.so
efac8000-efba18c7 /opt/intel/vtune/analyzer/bin/libMiniDE.so
ed914000-eda5cdb3 /opt/intel/vtune/analyzer/bin/libDBMgr.so
ed905000-ed910bf7 */opt/intel/vtune/analyzer/bin/libtbsana.so
ed8e5000-ed901387 /opt/intel/vtune/analyzer/bin/libsampling_utils.so
"Main Thread" id=1 idx=0x4 tid=23731 lastJavaFrame=0xffff8d5c
Stack 0: start=0xffdfe000, end=0xffffe000, guards=0xffe03000 (ok), forbidden=0xffe01000
Thread Stack Trace:
at (???.c)@0xed9091ff
at (???.c)@0xed9080c1
at (???.c)@0xed9074d7
at (???.c)@0xed9076bb
at (???.c)@0xed9c8f7f
at (???.c)@0xed9c673b
at (???.c)@0xed9c0be0
at (???.c)@0xefb289e2
at (???.c)@0xefb299e3
at (???.c)@0xefb025cc
at (???.c)@0xefaf7f45
at (???.c)@0xefb0f68b
at (???.c)@0xf039068a
at (???.c)@0xf038f69b
at (???.c)@0xf03d2363
at (???.c)@0xf0954339
at (???.c)@0xf0a93977
at (???.c)@0xf0a8ed7a
at (???.c)@0xf0a960fb
at (???.c)@0xf0a99a67
at (???.c)@0xf0aa2e3b
at (???.c)@0xf462751d
at (???.c)@0xf461d3f6
at (???.c)@0xf461c757
at (???.c)@0xf4682c7c
at (???.c)@0xf0a83f5a
at (???.c)@0xf32e7e0b
at (???.c)@0xf32e955c
at (???.c)@0xf32eda93
at (???.c)@0xf29a6f4c
at (???.c)@0xf299e778
at (???.c)@0xf29b2110
at (???.c)@0xf2984755
at (???.c)@0xf4c6531a
at (???.c)@0xf4c628d1
at (???.c)@0xf4cda6fc
-- Java stack --
at com/intel/vtune/shell/ShellPlugin.TuningBrowserNavigate()V(Native Method)
at com/intel/vtune/shell/tuningbrowser/views/TuningBrowserView$4.run(TuningBrowserView.java:320)
at com/intel/vtune/shell/tuningbrowser/views/TuningBrowserView$5.doubleClick(TuningBrowserView.java:328)
at org/eclipse/jface/viewers/StructuredViewer$1.run(StructuredViewer.java:796)
at org/eclipse/core/runtime/SafeRunner.run(SafeRunner.java:37)
at org/eclipse/core/runtime/Platform.run(Platform.java:843)
at org/eclipse/ui/internal/JFaceUtil$1.run(JFaceUtil.java:44)
at org/eclipse/jface/util/SafeRunnable.run(SafeRunnable.java:149)
at org/eclipse/jface/viewers/StructuredViewer.fireDoubleClick(StructuredViewer.java:794)
at org/eclipse/jface/viewers/AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1227)
at org/eclipse/jface/viewers/StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1158)
at org/eclipse/jface/util/OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:223)
at org/eclipse/jface/util/OpenStrategy.access$0(OpenStrategy.java:220)
at org/eclipse/jface/util/OpenStrategy$1.handleEvent(OpenStrategy.java:281)
at org/eclipse/swt/widgets/EventTable.sendEvent(EventTable.java:66)
at org/eclipse/swt/widgets/Widget.sendEvent(Widget.java:1085)
at org/eclipse/swt/widgets/Display.runDeferredEvents(Display.java:3166)
at org/eclipse/swt/widgets/Display.readAndDispatch(Display.java:2842)
at org/eclipse/ui/internal/Workbench.runEventLoop(Workbench.java:1914)
at org/eclipse/ui/internal/Workbench.runUI(Workbench.java:1878)
at org/eclipse/ui/internal/Workbench.createAndRunWorkbench(Workbench.java:419)
at org/eclipse/ui/PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org/eclipse/ui/internal/ide/IDEApplication.run(IDEApplication.java:95)
at org/eclipse/core/internal/runtime/PlatformActivator$1.run(PlatformActivator.java:78)
at org/eclipse/core/runtime/internal/adaptor/EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
at org/eclipse/core/runtime/internal/adaptor/EclipseAppLauncher.start(EclipseAppLauncher.java:68)
at org/eclipse/core/runtime/adaptor/EclipseStarter.run(EclipseStarter.java:400)
at org/eclipse/core/runtime/adaptor/EclipseStarter.run(EclipseStarter.java:177)
at jrockit/vm/RNI.c2java(IIII)V(Native Method)
at jrockit/vm/Reflect.invokeMethod(Ljava/lang/Object;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;(Native Method)
at sun/reflect/NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;(Native Method)
at sun/reflect/NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun/reflect/DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java/lang/reflect/Method.invoke(Method.java:585)
at org/eclipse/core/launcher/Main.invokeFramework(Main.java:336)
at org/eclipse/core/launcher/Main.basicRun(Main.java:280)
at org/eclipse/core/launcher/Main.run(Main.java:977)
at org/eclipse/core/launcher/Main.main(Main.java:952)
-- end of trace
Extended, platform specific info:
libc release: 2.3.4-stable
Elf headers:
libc ehdrs: EI: 7f454c46010101000000000000000000 ET: 3 EM: 3 V: 1 ENTRY: 008d9ee0 PHOFF: 00000034 SHOFF: 00177d7c EF: 0x0 HS: 52 PS: 32 PHN; 10 SS: 40 SHN: 67 STIDX: 66
libpthread ehdrs: EI: 7f454c46010101000000000000000000 ET: 3 EM: 3 V: 1 ENTRY: 00a25850 PHOFF: 00000034 SHOFF: 00019f00 EF: 0x0 HS: 52 PS: 32 PHN; 9 SS: 40 SHN:39 STIDX: 38
libjvm ehdrs: EI: 7f454c46010101000000000000000000 ET: 3 EM: 3 V: 1 ENTRY: 00057470 PHOFF: 00000034 SHOFF: 002dfe00 EF: 0x0 HS: 52 PS: 32 PHN; 4 SS: 40 SHN:19 STIDX: 16
===== END DUMP ===============================================================
Peter_W_Intel
I have concern on "OS version : Red Hat Enterprise Linux WS release 4 (Nahant Update 7)
Linux version 2.6.9-78.ELlargesmp (brewbuilder@ls20-bc2-14.build.redhat.com)" - large memory mode OS.
I don't think thathas been tested - but 2.6.9-78.ELsmp should be OK.
Red Hat* Enterprise Linux* 4 Update 7 2.6.9-78.EL
