Analyzers
5341 Discussions
Vtune error while loading on win 7 X64 Bit
mariongeomodeling_co
"Some Performance counters could not be loaded , try re-install application" , will get this error even after re-installing but the application will open
Peter_W_Intel
If you installed old product, should uninstall it successfully first, then install recent product.
If you failed to uninstall the tool, removing the folder of the product is useless - should clean the tool info in your system, then install recent update.
After installing the product, use below command to know supported PMU events in your syste:
> amplxe-runss -event-list
SergeyKostrov
Valued Contributor II
>>...should clean the tool info in your system... How it has to be done? Could you provide more details?
Peter_W_Intel
There are many tools can fix installation issue. For example, search "Microsoft installer clean up utility"
It helps to install latest product, based on no old product info remained in system. Let me know, after you installed new product, what you did, what error message was?
SergeyKostrov
>>...For example, search "Microsoft installer clean up utility" Thanks.
