Analyzers
5279 Discussions
Vtune having exception
prokash
I just downloaded Vtune Amplifier, configured ( or selected the tab for system profile). Profiled it with basic hotspot anlysis ( this is allowed for the config type "system profile").
It gives exeception when it tries to writeout the result. I've windbg hooked up, so if I say gh it crashes.
Why it is crashing??
The context is partially valid. Only x86 user-mode context is available.
WOW64 breakpoint - code 4000001f (first chance)
First chance exceptions are reported before any exception handling.
This exception may be expected and handled.
00000000`0ee429f4 cc int 3
32.2: kd:x86> gh
The context is partially valid. Only x86 user-mode context is available.WOW64 breakpoint - code 4000001f (first chance)First chance exceptions are reported before any exception handling.This exception may be expected and handled.00000000`0ee429f4 cc int 332.2: kd:x86> gh
Peter_W_Intel
Are you using latest VTune Amplifier XE 2011, Update 7?
If you want to do system wide profiling, please don't doit under user-mode sampling data collection (Hotspots, Concurrency, LocksAndWaits analysis), please do it under HW event-based sampling collection - like as lightweight-hotspots, and other predefined analysis types for your running processor.
Regards, Peter
SergeyKostrov
Valued Contributor II
Quoting prokash
This is what 'ntstatus.h' Win32 API header file "says" about thecode 4000001f:
// MessageId: STATUS_WX86_BREAKPOINT
// MessageText:
// Exception status code used by Win32 x86 emulation subsystem.
#define STATUS_WX86_BREAKPOINT ((NTSTATUS)0x4000001FL)
Sorry, but it isunclear why the exceptionhappened...
prokash
Thanks Peter!
Sorry for being late to respond...
I think the trail version has some exceptions. If I boot with BCD debug enabled, and run some sample tests ( at the collection time) it breaks into debugger. If I boot with normal boot option, then exception is absorbed...
-pro
Bernard
Your code is executing 0xcc instruction thus trigerring debugger breakpoint exception.Please post the full call stack.It is unknown why code path is executing int3 instruction.Sometime 0xcc is used as a padding for hot patching at runtime.
