Analyzers
5284 Discussions
Vtune kernel driver, build error "Failed to build the drivers"
MickeJ-IUA
Building the sepdk driver fails, below is my terminal output.
./build-driver --enable-config-check
C compiler to use: [ /sbin/gcc ]
C compiler version: 13.2.1
Make command to use: [ /sbin/make ]
Make version: 4.4.1
Kernel source directory: [ /lib/modules/6.8.1-1418.native/build ]
Kernel version: 6.8.1-1418
Cleaning workspaces ...
Done
Building socperf driver ...
/home/ello/Apps/sepdk/src/socperf/src/socperfdrv.c:214:13: warning: no previous prototype for ‘SOCPERF_Read_Data3’ [-Wmissing-prototypes]
214 | extern VOID SOCPERF_Read_Data3(PVOID data_buffer)
/home/ello/Apps/sepdk/src/socperf/src/socperfdrv.c:997:11: warning: no previous prototype for ‘SOCPERF_Switch_Group3’ [-Wmissing-prototypes]
997 | OS_STATUS SOCPERF_Switch_Group3(VOID)
/home/ello/Apps/sepdk/src/socperf/src/socperfdrv.c:1182:13: warning: no previous prototype for ‘lwpmudrv_Stop_Mem’ [-Wmissing-prototypes]
1182 | extern VOID lwpmudrv_Stop_Mem(VOID)
/home/ello/Apps/sepdk/src/socperf/src/socperfdrv.c:1400:1: warning: no previous prototype for ‘socperf_Service_IOCTL’ [-Wmissing-prototypes]
1400 | socperf_Service_IOCTL(IOCTL_USE_INODE struct file *filp,
/home/ello/Apps/sepdk/src/socperf/src/socperfdrv.c:1525:1: warning: no previous prototype for ‘socperf_Device_Control’ [-Wmissing-prototypes]
1525 | socperf_Device_Control(IOCTL_USE_INODE struct file *filp,
/home/ello/Apps/sepdk/src/socperf/src/socperfdrv.c:1562:1: warning: no previous prototype for ‘socperf_Device_Control_Compat’ [-Wmissing-prototypes]
1562 | socperf_Device_Control_Compat(struct file *filp,
/home/ello/Apps/sepdk/src/socperf/src/socperfdrv.c:1614:12: warning: no previous prototype for ‘SOCPERF_Abnormal_Terminate’ [-Wmissing-prototypes]
1614 | extern int SOCPERF_Abnormal_Terminate(void)
In file included from ./arch/x86/include/asm/mem_encrypt.h:15,
from ./include/linux/mem_encrypt.h:17,
from ./arch/x86/include/asm/processor-flags.h:6,
from ./arch/x86/include/asm/processor.h:5,
from ./arch/x86/include/asm/timex.h:5,
from ./include/linux/timex.h:67,
from ./include/linux/time32.h:13,
from ./include/linux/time.h:60,
from ./include/linux/stat.h:19,
from ./include/linux/module.h:13,
from /home/ello/Apps/sepdk/src/socperf/src/socperfdrv.c:61:
/home/ello/Apps/sepdk/src/socperf/src/socperfdrv.c: In function ‘socperf_Load’:
./include/linux/init.h:184:22: error: passing argument 1 of ‘class_create’ from incompatible pointer type [-Werror=incompatible-pointer-types]
184 | #define THIS_MODULE (&__this_module)
| struct module *
/home/ello/Apps/sepdk/src/socperf/src/socperfdrv.c:1738:34: note: in expansion of macro ‘THIS_MODULE’
1738 | pmu_class = class_create(THIS_MODULE, SOCPERF_DRIVER_NAME);
In file included from ./include/linux/device.h:31,
from ./include/linux/cdev.h:8,
from /home/ello/Apps/sepdk/src/socperf/src/socperfdrv.c:69:
./include/linux/device/class.h:228:54: note: expected ‘const char *’ but argument is of type ‘struct module *’
228 | struct class * __must_check class_create(const char *name);
/home/ello/Apps/sepdk/src/socperf/src/socperfdrv.c:1738:21: error: too many arguments to function ‘class_create’
./include/linux/device/class.h:228:29: note: declared here
cc1: some warnings being treated as errors
make[3]: *** [scripts/Makefile.build:243: /home/ello/Apps/sepdk/src/socperf/src/socperfdrv.o] Error 1
make[3]: *** Waiting for unfinished jobs....
make[2]: *** [Makefile:1921: /home/ello/Apps/sepdk/src/socperf/src] Error 2
make[1]: *** [Makefile:145: default] Error 2
make: *** [Makefile:215: default] Error 2
yuzhang3_intel
A similar issue was reported in the forum, we are investigating now. VTune should work if you don't care about power metrics. SoCWatch driver is for power measurement.
yuzhang3_intel
Could you provide the platform and VTune release information? BTW, the public 2024.1 is released, please try with the latest version, thanks.
MickeJ-IUA
Thank you. I am using Linux.
I download "sepdk.tar.gz" from the Intel Webpage Intel® VTune™ Profiler Sampling Driver Downloads
This documentation page with ID nr 657847 states it was updated 1/23/2024
Tell me if this driver download link is correct.
yuzhang3_intel
After you install VTune Profiler, the driver source is there as below, you can build the source, don't need to download from web page.
/opt/intel/oneapi/vtune/latest/sepdk
Following the steps in the link to build your driver.
https://www.intel.com/content/www/us/en/docs/vtune-profiler/user-guide/2024-0/build-install-sampling-drivers-for-linux-targets.html#GUID-CC4C2F86-21A6-402A-97B0-3DA1FFD2C8F4
MickeJ-IUA
Thank you. The documentation page you refer to has a note:
NOTE:
If the current version of the sampling driver that is shipped with the VTune Profiler installation does not suit your needs, for example, due to a recent change in the Linux* kernel, you can find the latest version of the sampling driver on the Sampling Driver Downloads page.
When compilation failed i followed the note in the installation documentation you referred to. quote "you can find the latest version of the sampling driver on the Sampling Driver Downloads page." If the latest version is not there you need to correct the documentation.
After upgrading and testing again building one of the drivers failed.
ERROR: Failed to build socwatch2_15-x32_64-6.8.2-1420.nativesmp.ko driver
I post the complete build log in the attached txt file.
yuzhang3_intel
MickeJ-IUA
Ok
i will proceed without the power measurement driver
Thank you
