Analyzers
Vtune:no data to show
BadOne
I run sample matrix in vtune and get no error and waring.
but I can't see the bottom-up,it shows:
DiyaN_Intel
Could you please share the following details-
1. Sample reproducer code.
2. VTune version.
3. Exact steps and the commands used.
4. OS details.
5. Processor and kernel details .
6. Self-checker logs.
To get the self-checker logs you have to make sure that the VTune self-checker script is running fine. This is to validate that appropriate drivers are installed and the system is set up properly to collect the performance data.
The "vtune-self-checker.sh" script is available from <install-dir>/bin64 on the Windows or Linux system on which you installed VTune Profiler.
On running this script, it will create a log file and display the location of the log file. Kindly share that file with us so that we can verify it from our side.
Thanks and Regards,
Diya
DiyaN_Intel
We have not heard back from you.
Could you please share the above details so that we can try to investigate the issue from our end?
Diya
DiyaN_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks and Regards,
Diya
