Analyzers
5273 Discussions
amplxe: Error: [Instrumentation Engine]: Pin is out of memory
Giszczak__Jonathan
amplxe: Collection failed.
amplxe: Internal Error
Environment:
  • Ubuntu 18.04, both in VirtualBox and bare metal
  • vtune_amplifier_2019.6.0.602217
  • 128GB system RAM, not remotely close to exhausted
Source Code:
https://github.com/EOSIO/eos
Run
scripts/eosio_build.sh -o RelWithDebInfo
Run
scripts/eosio_install.sh
Run
H=`pwd`
DATE=`which date`
TIMESTAMP=`$DATE +"%Y-%m-%d-%H-%M-%S"`
NODEOS=~/eosio/2.0/bin/nodeos
NVER=`$NODEOS --version`
/opt/intel/vtune_amplifier/bin64/amplxe-cl -c hotspots -app-working-dir=$H -data-limit=2048 -finalization-mode=full \
  -inline-mode=on -mrte-mode=native -target-duration-type=veryshort \
  -r $H/hotspots-$NVER-$TIMESTAMP -- \
  ~/eosio/2.0/bin/nodeos --data-dir "$H/data" --config-dir "$H/config" \
  --wasm-runtime eos-vm --eos-vm-oc-enable --force-all-checks --disable-replay-opts \
  --terminate-at-block 1000 \
  > "$H/stdout.txt" 2> "$H/stderr.txt"
Ekaterina_L_Intel
Hi Jonathan,
Can you please upgrade to the recently released VTune Profiler 2020 version (available at Intel Registration Center) and verify if the problem is reproducible? Try on bare metal first.
If the problem persists, please set the debug variables below and then re-run the amplxe-cl collection.
TPSS_DEBUG=1
AMPLXE_LOG_LEVEL=TRACE
Once collection failed, please zip the result folder and share here for further exploration on our side.
Regards, Katya
Giszczak__Jonathan
The problem did persist.  Attached is the contents of the results directory generated during a bare metal run, with the '-bad' suffix auto-appended by the software.
-Jonathan
