Analyzers
base relocation problem
gte274s
I am using VTune performance analyzer to analyzea fortran program eqm2.exe which was built by Compaq Visual Fortran 6.5 with debug mode.When I tried tocollect the call graph data, it gives me error message like this:
The following modules were created without base relocations: ...eqm2.exe.Base relocations are requiredin orderto obtain call graph data. If your application is developed using Microsoft Visual C++ or Microsoft Visual Basic*, add the flag "/fixed:no" to the link command line or set the environmentvariable "LINK=/fixed:no." Restart the Development Environment and rebuilt your application.
I have set the environment variable and add the flag, but nothing good happened. Does anyone know how to fix this problem? Thanks for your time.
Erika
bnshah
That should work. However it may be better to ask Steve Lionel in the Fortran compiler forum
