Analyzers
5341 Discussions
./boot-script: 357: cannot create /usr/local/sbin/sep5-load.sh: Directory nonexistent
Stolk
When I try to install vtune on Ubuntu26.04 using this guide, with apt method, I get this error when setting up vtune package:
Setting up intel-oneapi-vtune (2026.3.0-5)…
C compiler version: 15.2.0
Make version: 4.4.1
Kernel version: 7.0.0-27-generic
Cleaning workspaces ...
Done
Building sep driver ...
warning: the compiler differs from the one used to build the kernel
  The kernel was built by: x86_64-linux-gnu-gcc (Ubuntu 15.2.0-16ubuntu1) 15.2.0
  You are using:           gcc (Ubuntu 15.2.0-16ubuntu1) 15.2.0
Skipping BTF generation for sep5.ko due to unavailability of vmlinux
Done
Building pax driver ...
Skipping BTF generation for pax.ko due to unavailability of vmlinux
Done
Building vtsspp driver ...
make[1]: Entering directory '/home/intel/oneapi/vtune/2026.3/sepdk/src/vtsspp'
Skipping BTF generation for vtsspp.ko due to unavailability of vmlinux
make[1]: Leaving directory '/home/intel/oneapi/vtune/2026.3/sepdk/src/vtsspp'
Done
Building socwatch driver ...
Building drivers for Linux target
/lib/modules/7.0.0-27-generic/build will be used as the kernel build directory
Using alternate compiler '/bin/gcc'
Removing previously built driver and scripts from /home/intel/oneapi/vtune/2026.3/sepdk/src/socwatch/drivers
'-c /bin/gcc -l -k /lib/modules/7.0.0-27-generic/build' options will be used to build the SoCWatch driver
************ Building socwatch2_16-x32_64-7.0.0-27-genericsmp.ko driver ************
Using C compiler = /bin/gcc
Using kernel build dir = /lib/modules/7.0.0-27-generic/build
No module symvers file found
Using common inc dir = /home/intel/oneapi/vtune/2026.3/sepdk/src/socwatch/socwatch_driver/../common/include
"/lib/modules/7.0.0-27-generic/build/include/linux/cpufreq.h" exists!
"/lib/modules/7.0.0-27-generic/build/include/linux/device/class.h" exists!
Using file name sw_driver
Make args = KERNEL_SRC_DIR=/lib/modules/7.0.0-27-generic/build CPUFREQ_FIX_BACKPORTED=1 CLASSCREATE_CHANGE_BACKPORTED=1 DO_DEBUG_BUILD=0 DO_PROFILING=0 COMMON_INC_DIR=/home/intel/oneapi/vtune/2026.3/sepdk/src/socwatch/socwatch_dri
ver/../common/include MODULE_SYMVERS_FILE= FILE_NAME=sw_driver
make[1]: Entering directory '/home/intel/oneapi/vtune/2026.3/sepdk/src/socwatch/socwatch_driver'
make -C /lib/modules/7.0.0-27-generic/build M=/home/intel/oneapi/vtune/2026.3/sepdk/src/socwatch/socwatch_driver clean
make[2]: Entering directory '/usr/src/linux-headers-7.0.0-27-generic'
make[3]: Entering directory '/home/intel/oneapi/vtune/2026.3/sepdk/src/socwatch/socwatch_driver'
make[3]: Leaving directory '/home/intel/oneapi/vtune/2026.3/sepdk/src/socwatch/socwatch_driver'
make[2]: Leaving directory '/usr/src/linux-headers-7.0.0-27-generic'
make[1]: Leaving directory '/home/intel/oneapi/vtune/2026.3/sepdk/src/socwatch/socwatch_driver'
DO_DRIVER_PROFILING=0
INCDIR_1=/home/intel/oneapi/vtune/2026.3/sepdk/src/socwatch/socwatch_driver/../common/include
make -C /lib/modules/7.0.0-27-generic/build M=/home/intel/oneapi/vtune/2026.3/sepdk/src/socwatch/socwatch_driver modules PWD=/home/intel/oneapi/vtune/2026.3/sepdk/src/socwatch/socwatch_driver
  CC [M]  src/sw_driver.o
  CC [M]  src/sw_hardware_io.o
  CC [M]  src/sw_output_buffer.o
  CC [M]  src/sw_tracepoint_handlers.o
  CC [M]  src/sw_collector.o
  CC [M]  src/sw_mem.o
  CC [M]  src/sw_internal.o
  CC [M]  src/sw_file_ops.o
  CC [M]  src/sw_ops_provider.o
  CC [M]  src/sw_trace_notifier_provider.o
  CC [M]  src/sw_reader.o
  CC [M]  src/sw_telem.o
  CC [M]  src/sw_pmt.o
  CC [M]  src/sw_counter_list.o
  CC [M]  src/sw_pci.o
  LD [M]  socwatch2_16.o
  MODPOST Module.symvers
  CC [M]  socwatch2_16.mod.o
  CC [M]  .module-common.o
  LD [M]  socwatch2_16.ko
  BTF [M] socwatch2_16.ko
Skipping BTF generation for socwatch2_16.ko due to unavailability of vmlinux
************ Built drivers are copied to /home/intel/oneapi/vtune/2026.3/sepdk/src/socwatch/drivers directory ************
Done
Done building the drivers
Configuring sep5 boot script with the following options:
    driver files = /opt/intel/oneapi/vtune/2026.3/sepdk/src/.
Creating systemd load script /usr/local/sbin/sep5-load.sh ...
chmod: cannot access '/usr/local/sbin/sep5-load.sh': No such file or directory
Unable to create systemd load script ... exiting.
Stolk
To fix this, I did:
$ sudo mkdir /usr/local/sbin
Then:
$ sudo apt-get install --reinstall intel-oneapi-vtune
Which gets me:
Done
done.
Creating systemd boot config file /lib/systemd/system/sep5.service ...
done.
Configuring autoload of sep5.service service ...
Created symlink '/etc/systemd/system/multi-user.target.wants/sep5.service' → '/usr/lib/systemd/system/sep5.service'.
done.
I think it will be a good idea to add the creation of the installation dir to the debian setup script.
Stolk
Sadly, vtune-gui just sits there at the splash screen, no TTY output, no progression to show a GUI.
$ source /opt/intel/oneapi/vtune/latest/vtune-vars.sh
$ vtune-gui
See attached file for self checker output.
