Analyzers
5342 Discussions
cannot resize application window width beyond screen size
Fabio_Cannizzo
I just installed Vtune 2016 Update 2 (build 444464) on Windows 7.
I have 4 vertical screens side by side.
If I move the VTune window, I have no problem in positioning it so that it spans over two screen, but I cannot emlarge the width of the VTune window any larger than the width of one single screen.
I suspect this is a bug.
Any suggestion from Intel support? Thanks
Fabio
David_A_Intel1
This issue was recently reported by another user and is resolved in the 2017 beta release.  It should, therefore, be resolved in a future commercial release.
Andrew_B_4
Are there any plans to release this fix in an update to the 2016 package?
VTune works best when you can see its massively-horizontal interface, and being able to resize across multiple monitors would be extremely useful.
Vitaly_S_Intel
The fix for issue mentioned by MrAnderson is included in VTune Amplifier XE 2016 Update 3 which should appear for download in a few days.
David_A_Intel1
Update 3 is available as of Monday.
high_end_c_
Is it possible to have dynamically resizing buttons such as "Choose Analysis" - these are way too big on limited screen estate (and partially un-ncessary once one knows the steps to set up, run, & analyse
