Analyzers
5259 Discussions
''-collect does't accept option -format'', how to solve it? is version difference problem?
Qun_L_
I am using amplxe-cl to process analysis, but when I was using the same script which works no problem in Vtune Amplifier 2011 has problem occurred in Vtune Amplifier 2016, the script is below:
/usr/foo/intel/vtune_amplifier_xe_2011/bin64/amplxe-cl --collect custom_analysis_0 -follow-child -target-duration-type=short -allow-multiple-runs -no-analyze-system -data-limit=100 -result-dir=/usr/foo/intel/MyProjects/test/dealII -format csv -report-output=/usr/foo/intel/MyProjects/test/dealII -summary -- /usr/foo/cpu2006/rundealII
the problem occurred described as:
So does anyone knows this problem? I tried make changes according the newest reference documents, but still not work, hope anyone can help.
Thank you.
Dmitry_P_Intel1
Hello Qun,
Since currently -collect command does not operate with report options like -format or -report-output you can divide it by to CL invocations:
>amplxe-cl --collect custom_analysis_0 -follow-child -target-duration-type=short -allow-multiple-runs -no-analyze-system -data-limit=100 -result-dir=/usr/foo/intel/MyProjects/test/dealII  -- /usr/foo/cpu2006/rundealII
>amplxe-cl -report summary -format csv -report-output=/usr/foo/intel/MyProjects/test/dealII -r /usr/foo/intel/MyProjects/test/dealII
Hope this helps.
Thanks & Regards, Dmitry
Qun_L_
Or is anyone knows where can download Vtune Amplifier XE 2011? I did not find the archives on this website...
Dmitry_P_Intel1
Hello Qun,
Hope this helps.
Qun_L_
dmitry-prohorov (Intel) wrote:
Hello Qun,
Hope this helps.
Hi Dmitry,
Thank you for this, I have tried in this way, so we cannot define that two in one command line right?
Best,
Qun
Dmitry_P_Intel1
Hello Qun,
This is correct, VTune "-collect" command does not accept report related knobs.
Qun_L_
Thank you, Dmitry-prohorov.
Qun_L_
Hello Qun,
Hope this helps.
Hi Dmitry,
Do you know this problem?
I have installed the Vtune in a new computer, but it showed:
amplxe: Error: File "/home/SPEC/cpu2006/scripts/runastar" is not an executable binary.
It works well in my previous computer, I am sure.
Thank you.
Vitaly_S_Intel
Well, this error message says that the file "runastar" that you specified as an application to launch is not an executable. Please check this file is accessible on your new system and has executable permission.
Qun_L_
Thank you. Have solved this in another post. So, do you know why it can not output CSV file?
