Analyzers
5334 Discussions
command line execution and project file
newport_j
When you use amplxe-cl to analyze a binaryfile you do not create a project directory or file. It seems all you do is create dirictories like r000hs. How does one use this like one can use a *proj file?
But where is the project file?
What if you want to go back and use that output in another way?
Any help appreaciated thanks in advance.
Newport_j
Mark_D_Intel
There is no project file created by or used by the command line. If you want to save some options and rerun the same (or similar) analysis, create a simple shell script.
You can use the -report option to view the data (use '-help report' to get a list of reports). Use the -result-dir option to specify a result directory (by default it will use the one with the highest number, regardless of any suffix, like 'hs').
The results can be viewed in the GUI, either with File->Open->Result, or specify the marker file (in the result directory) on the command line (eg 'amplxe-gui r000hs/r000hs.amplxe')
newport_j
I need a referenceto a VTUNE Document such as a usage manualas to how to do this. I am only using the quickstart tutorial. That explains very little aout the command line usage in VTUNE.
Any help appreciated. Thanks in adavance.
Newport_j
Mark_D_Intel
At the top of the VTune forum page are links to the manuals
http://software.intel.com/en-us/articles/intel-vtune-amplifier-xe-documentation/
Look for "Command line interface support"
