Analyzers
5341 Discussions
command line -no-auto-finalize
Ronald_G_2
A couple of questions on finalization.
We're working on Knights Landing processor.  Obviously finalization on KNL is slower than on Xeon, taking somewhere between 5 to 15 minutes for a moderately large code.  We started using -no-auto-finalize on the KNL collection and finalizing in the GUI ( open an empty project, set up the Properties with binary, source search, bin search.  Then Open Results - loading the results finalizes in the GUI and all is good. )
Couple of questions:
Why isn't there a command line finalization command like in Vtune?  something like 'advixe-cl  -finalize -project dir <foo> -search-dir all:r=<foo>
I would like a command line way to finalize so collection could be done on the KNL and I could finalize from the command line on Xeon.  Please add a Feature Request for this.  It would be helpful to run batch tests overnight w/o the GUI and have everything collected and finalized in batch command line mode.
Next question:  is finalization a one-time event?  Is there a Re-finalize results like in Vtune?  Can one re-finalize results, and if so, is there a hidden button or a command line command to do this?
Ron
Kevin_O_Intel1
You can also remove the .norun file from the result directory and then open the results and it will refinalize
Kevin_O_Intel1
Hi Ron,
I can file a feature request.
Finalization is a one time event. I think you can delete move some files to force re-finalization. Let me verify.
Kevin
Kevin_O_Intel1
To force finalization you can remove
rank.*/hs***/sqlite-db sub-directory
I'm filing a CQ Feature request for the above functionality you mention
Kevin_O_Intel1
Ronald_G_2
Just to confirm - Is there a CQ Feature Request for advixe-cl to support a separate finalization command similiar to that provided by Vtune, an advixe-cl  -finalize <args>  sort of functionality?
