Analyzers
5337 Discussions
compare two FIFO implementation
softarts
see the single-producer/single consumer FIFO code below,seems code1 is compact,and only have 1 if-else branch.
time: the former cost about avg. 160ns per insert (by clock_gettime) latter cost about 20 ns per insert(surprised me! ).
the CPI result:former is about 30,latter is about 8.
I don't check other events
the reason might be the code1 has an expensive insruct "div",but how to prove it?
code1:
bool insert( const T &rtItem )
uint32_t ww = (uint32_t) atomic_read( &w );
uint32_t rr = (uint32_t) atomic_read( &r );
if (predict_true(ww - rr != size))
f[ ww % size ] = rtItem;
atomic_inc( &w );
return true;
return false;
code2:
uint32_t nw;
bool tRet = false;
if ( predict_true( ( ww + 1 ) < size ) )
nw = ww + 1;
else
nw = 0;
if ( predict_true( nw != rr ) )
f[ ww ] = rtItem;
atomic_set( &w, nw );
tRet = true;
return tRet;
Vladimir_T_Intel
Quoting - softarts
Look a the cycle count event distribution over the code (disassembly view would be more useful). You can find out which instruction or group of instructions cost the most clock ticks.
